Re: 2.2 Turbo looses power after warmup when boost hits [Re: kwikblownhemi] #948448
04/10/11 10:18 AM
04/10/11 10:18 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Ya also wondering about the fuel pressure, maybe pump/regulator/filter issue.
Re: 2.2 Turbo looses power after warmup when boost hits [Re: feets] #948449
04/10/11 08:52 PM
04/10/11 08:52 PM
Ortonville, MI
RoadRnnr69 Offline
Keyster
RoadRnnr69  Offline
Keyster
Ortonville, MI
These cars are notorious for vacuum issues. One thing you must remember is that vacuum leaks will NOT throw engine codes.
Not true! A leak in the baro line will cause all sorts of codes to set.
I guess that one would. I was thinking about all the mystery issues I had with my Shelby Chargers over the years. If there was no engine light I either had a vacuum leak or hall effect sensor issue.
I really enjoyed those little cars but they drove me nuts when something wasn't right.
My Shelby Charger has a "Power Loss" light lit??
I parked it about 5 years ago.
Re: 2.2 Turbo looses power after warmup when boost hits [Re: IMGTX] #948450
04/10/11 09:26 PM
04/10/11 09:26 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
I have a GLHS that has been overboosting for 2years. I think I am going to pull all of the vacume lines and switch to a Granger valve. These turbos can be a pain in the butt.
Re: 2.2 Turbo looses power after warmup when boost hits [Re: DodgeCharger] #948451
04/12/11 06:56 PM
04/12/11 06:56 PM
michigan woods
imfixinmopars426 Offline
michigan woods
fuel filter?
Re: 2.2 Turbo looses power after warmup when boost hits [Re: feets] #948452
04/18/11 03:15 PM
04/18/11 03:15 PM
IMGTX Offline OP
IMGTX  Offline OP
Thanks for the help.
I still haven't figured it out but I only get to look at it about once every two weeks since my son and I work opposing schedules. He has been shutting it off while driving to reset whatever goes wrong and it is fine for a few more miles/minutes so he hasn't just left me the car to deal with and when I get in the car with him it runs fine.
I replaced the fuel pump, Filter and all rubber lines about 3 months ago. That does not mean it isn't a fuel problem but maybe I got a bad pump.
Again thanks for the help and I will let you know how it goes.
Re: 2.2 Turbo looses power after warmup when boost hits [Re: IMGTX] #948453
04/18/11 03:41 PM
04/18/11 03:41 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
I seem to remember a similar problem in my GLHS Omni. Ended up being the intake air temp sensor. Put a new sensor and pigtail on the harness and all was good.
Re: 2.2 Turbo looses power after warmup when boost hits [Re: feets] #948454
05/02/11 10:02 PM
05/02/11 10:02 PM
IMGTX Offline OP
IMGTX  Offline OP
Fuel pump getting hot?
As stated above, get a fuel pressure gauge on that thing and tell us what it says.
BING BING BING we have a winner.
I finally got a chance to look at it again yesterday.
I had triple checked the vacuume lines and all were OK. SO I checked the fuel. Fuel presure was OK at idle but flow was pitiful.
I pulled the recently replaced pump and the rubber gasket that holds the pump was starting to melt or it was cheap junk rubber and the fuel started to disolve it.
In either case I replaced the fuel pump with a MOPAR brand and it seems to be fine now. Cheap Airtex crap.
Thanks to all who assisted me.
Re: 2.2 Turbo looses power after warmup when boost FIXED [Re: IMGTX] #948455
05/04/11 06:28 PM
05/04/11 06:28 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
What was the problem?
- Stu Harmon
Re: 2.2 Turbo looses power after warmup when boost FIXED [Re: feets] #948456
05/05/11 04:56 PM
05/05/11 04:56 PM
IMGTX Offline OP
IMGTX  Offline OP
Like you said the fuel pump was overheating.
This rubber mess was supposed to be like a set of fingers holding the pump. Not a molten sticky glob. The pump was OK until it got too warm and started freaking out.
