Mod SS springs for Caltracs ? #948156
03/11/11 02:52 AM
03/11/11 02:52 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Why couldnt a guy remove a leaf or 2 on the Super stock springs and use them with Caltrac bars ?
Anyone tried this ?
Re: Mod SS springs for Caltracs ? [Re: 493_DART] #948157
03/11/11 08:05 AM
03/11/11 08:05 AM
ohio
dbran451 Offline
dbran451  Offline
ohio
I did that several years ago removed one leaf on each spring has worked for me
Re: Mod SS springs for Caltracs ? [Re: dbran451] #948158
03/11/11 08:19 AM
03/11/11 08:19 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
ok ... no problems ? car hooks consistent ? are you using a T brake ?
Re: Mod SS springs for Caltracs ? [Re: 493_DART] #948159
03/11/11 07:20 PM
03/11/11 07:20 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
I normally foot break but have a tbrake and do play with it on occasion 60 foots are low 1.40s and have been in the high 1.30s there seems to be very little difference between the two, the wheels do get a little higher with the brake
Re: Mod SS springs for Caltracs ? [Re: dbran451] #948160
03/11/11 09:54 PM
03/11/11 09:54 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Ok to steal show a little, so than equal amount of leafs on both sides or leave 1 extra in the right side as you would without caltracs?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Mod SS springs for Caltracs ? [Re: kilroy] #948161
03/12/11 12:37 AM
03/12/11 12:37 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Re: Mod SS springs for Caltracs ? [Re: Hot 340] #948162
03/12/11 05:13 AM
03/12/11 05:13 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I was discussing this with an local mopar guy and we were saying ... why wouldnt this work ?? Seems like you just need a NON stiff leaf spring to work with the Caltracs...... yes?
Ive already got the Rancho 9 ways on mine so ...
Re: Mod SS springs for Caltracs ? [Re: 493_DART] #948163
03/12/11 09:51 AM
03/12/11 09:51 AM
ohio
dbran451 Offline
dbran451  Offline
ohio
I removed one leaf from each side the springs are just there to hold the weight not for traction.I also clamped the leafs
Re: Mod SS springs for Caltracs ? [Re: dbran451] #948164
03/12/11 09:57 AM
03/12/11 09:57 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
on a 6 or 7 leaf spring that is only removing a short section that would only effect the front segment relating to windup.
Re: Mod SS springs for Caltracs ? [Re: blownzoom440] #948165
03/13/11 05:53 AM
03/13/11 05:53 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
yet the guy above is doing it with success......
so have you tried this yourself ?
Re: Mod SS springs for Caltracs ? [Re: 493_DART] #948166
03/13/11 08:11 AM
03/13/11 08:11 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
He didn't say WHICH leaf was removed...
Nautilus Racing-
Re: Mod SS springs for Caltracs ? [Re: 493_DART] #948167
03/13/11 09:42 AM
03/13/11 09:42 AM
tboomer Offline
tboomer  Offline
Kevin...Did you want me to call Jeff,yet? Too bad my B body ones won't work....You could have them!!
Re: Mod SS springs for Caltracs ? [Re: 493_DART] #948168
03/13/11 10:13 AM
03/13/11 10:13 AM
ELYRIA,OH
ELYRIA,OH
no but i will sure think about it.i have 3800# springs and could take out even more maybe.[3 leaves]i will try to find a pic of my springs to post.
ft segment driver side.
Re: Mod SS springs for Caltracs ? [Re: 493_DART] #948169
03/13/11 10:29 AM
03/13/11 10:29 AM
ELYRIA,OH
ELYRIA,OH
the full stack on ps side.
Re: Mod SS springs for Caltracs ? [Re: blownzoom440] #948170
03/13/11 10:42 AM
03/13/11 10:42 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I'm thinking that you are going to want to duplicate the mono leaf they sell, only with multiple leafs. i.e., full length segments from front eye to rear eye, stopping when you achieve the correct checking rate, to support the rear of the car.
Re: Mod SS springs for Caltracs ? [Re: Leigh] #948171
03/13/11 10:54 AM
03/13/11 10:54 AM
ELYRIA,OH
ELYRIA,OH
Re: Mod SS springs for Caltracs ? [Re: Leigh] #948172
03/14/11 02:54 AM
03/14/11 02:54 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
how can i estimate the spring rate ?
or would it be a trial and error deal
Re: Mod SS springs for Caltracs ? [Re: 493_DART] #948173
03/14/11 07:20 AM
03/14/11 07:20 AM
ELYRIA,OH
ELYRIA,OH
i woud think a front to raer % of total weight would be a start.i think removing 1/2 of the springs would be a place to start.i believe it is the first 2 or 3 springs that hold the car weight.i am just quessing tho.
Re: Mod SS springs for Caltracs ? [Re: blownzoom440] #948174
03/16/11 11:23 PM
03/16/11 11:23 PM
K
Kiddart Offline
Kiddart  Offline
K
what happened?? was waiting ti hear some more good talk on this. I could save a bunch of cash with this idea
Thank you
Kiddart
Re: Mod SS springs for Caltracs ? [Re: Kiddart] #948175
03/17/11 12:46 AM
03/17/11 12:46 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
id like to hear some more too
i hope to order my caltracs soon
