Re: one-man brake bleeder kit [Re: Commando1] #947007
03/10/11 11:10 AM
03/10/11 11:10 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Disregard the fact that this is clearly a motorcycle and you will setup your Mityvac the same way for bleeding on a car.
Make sure you've got the small length of tube in the underside of the reservoir cap.
Some like to pull a vacuum (start pumping handle) and then crack the bleeder. Some like to just crack the bleeder and start pumping. Either way, you'll do the same job.
An important note: I've used the Mityvac on a number of applications and if you pay close enough attention you WILL notice that you pull air in and around the threads of the bleeder screw. As someone mentioned, it wouldn't be a terrible idea to put some teflon tape around the threads. Just make sure you don't hang the thread too long over the seat/hole on the screw itself.
Re: one-man brake bleeder kit [Re: Commando1] #947008
03/10/11 11:12 AM
03/10/11 11:12 AM
GA
Boosted Offline
Boosted  Offline
GA
I use this one..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: one-man brake bleeder kit [Re: Mr T2U] #947009
03/10/11 03:00 PM
03/10/11 03:00 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
whats wrong with putting a rubber hose on the bleeder screw and putting the other end in a soda bottle with a bit of brake fluid covering the other end of the hose, open the bleeder screw then slowly pump the brakes?
i have been bleeding brakes this way for the last 20 years without problems.
best of all it doesn't cost you anything for the home made tool.
The Mityvac is great for more than just bleeding brakes. I used it last weekend to check the vacuum actuators on my truck's A/C box. After reassembling the system I used the Mityvac again to check for vacuum leaks and proper function.
It came in handy when I needed to drain a contaminated master cylinder without flushing the junk through the lines.
They're good to have around the garage.
- Stu Harmon
Re: one-man brake bleeder kit [Re: Pat_Whalen] #947010
03/10/11 05:44 PM
03/10/11 05:44 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Just finished. Well, that was easy once somebody shows ya.
Not used to this new-fangled easy stuff. What's next? Some thingy with a disco light to tell you your timing?
Re: one-man brake bleeder kit [Re: Commando1] #947011
03/11/11 02:44 PM
03/11/11 02:44 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Well, got her done.. I used a combination of old and new. I used the old-fashion way of a jar with fluid and the hose submerged in it for the rears. The jar fit rather nicely perched on the leaf springs. The front, I used the one-man bleeder system I purchased. Worked out great. For those curious, I found some brake fluid used in Formula I racing applications. Being that the engine compartment of the Daytona can get rather hot in the Summer, I wanted the extra protection of durability of this performance fluid. Last year, the fluid would get VERY hot around the master cylinder.
Troy
Houston Mopar Connection Club
Re: one-man brake bleeder kit [Re: hemi68charger] #947012
03/11/11 02:45 PM
03/11/11 02:45 PM
Houston, Tx
Houston, Tx
Rt Front starting to bleed.. Kit worked out great...
Troy
Re: one-man brake bleeder kit [Re: hemi68charger] #947013
03/11/11 02:45 PM
03/11/11 02:45 PM
Houston, Tx
Houston, Tx
All the air gone and new fluid passing through
Troy
Re: one-man brake bleeder kit [Re: hemi68charger] #947014
03/11/11 02:46 PM
03/11/11 02:46 PM
Houston, Tx
Houston, Tx
Performance fluid I used with a very high boiling point.. It is used in racing applications like road racing and Formula I.
Troy
Re: one-man brake bleeder kit [Re: Aero426] #947015
03/12/11 12:01 AM
03/12/11 12:01 AM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
I have Speedbleeders on a couple cars. They are bleeder screws that have a small spring and check ball inside. The threads are teflon coated so you won't get air leaking past the threads. Just open it up and pump away. All popular sizes available. $7 each. They are great for a track car or for bleeding by yourself.
Speedbleeder Website
I use Russell speed bleeders. Love em.
Eric
Re: one-man brake bleeder kit [Re: Erics5th] #947016
03/12/11 03:15 AM
03/12/11 03:15 AM
hooziewhatsit Online content
hooziewhatsit  Online Content
Stupid question.. but do you still have to bench bleed the master if you're using a pressure bleeder to push fluid through the system? It seems like you could remove the lines and add pressure and it would blow fluid though. Then hook the lines up and continue bleeding. OR does the plunger have to move to get all the air out?
I only ask since in my cars, there's only 2" of clearance between the MC and the strut tower. Makes it a PITA to re-attach the lines after a bench bleed, meanwhile fluid is dripping everywhere, probably getting air back in the MC
I may have to fashion a plate that sits on the MC and has a connection for the air compressor
Re: one-man brake bleeder kit [Re: hooziewhatsit] #947017
03/12/11 02:11 PM
03/12/11 02:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have always bench bleed and then mount up MC. Then push fluid through the whole system with a pressure bleeder. Never tried it dry, didn't want have to do it twice(installing a new MC)
Re: one-man brake bleeder kit [Re: Challenger 1] #947018
03/12/11 07:52 PM
03/12/11 07:52 PM
Houston, Tx
Houston, Tx
For me, I "bench" bleed my master cylinder on the car. I have old front and rear brake lines that I have cut and formed to empty out into the reservoir. I just fill up the front and rear reservoirs and pump away.
Troy
Re: one-man brake bleeder kit [Re: Challenger 1] #947019
03/12/11 07:56 PM
03/12/11 07:56 PM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
my females did not like either
Re: one-man brake bleeder kit [Re: TheRamMan] #947020
03/12/11 07:57 PM
03/12/11 07:57 PM
TheRamMan Offline
TheRamMan  Offline
just remember pressure bleed dont work with metering valves
