Re: Spool. Ok for the street? [Re: galen] #946890
03/10/11 08:32 PM
03/10/11 08:32 PM
georgia
1340busa Offline
1340busa  Offline
georgia
i drive a 72 340 demon with 3.91 and 28 inch tall tires. it has a spool and moser axles. it is a everyday street car no problems. it has superstock springs and mini tubs. i love the spool.
Re: Spool. Ok for the street? [Re: 1340busa] #946891
03/10/11 10:27 PM
03/10/11 10:27 PM
I will be putting a Detroit locker in my street/ strip car.
Re: Spool. Ok for the street? [Re: ] #946892
03/10/11 10:44 PM
03/10/11 10:44 PM
Thanks for all the input guys. I am going to advise him to use a sure grip style diff. His car will see little track time.
Re: Spool. Ok for the street? [Re: Challenger 1] #946893
03/10/11 10:53 PM
03/10/11 10:53 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I drive a spooled jeep on the road, but it has a 14 bolt rear, and 40" tall tires..
There's no sense in telling people how foolish you are.
HUH???!?!?!
Foolish how?
Re: Spool. Ok for the street? [Re: ] #946894
03/11/11 04:27 PM
03/11/11 04:27 PM
an8sec70cuda Offline
Nothing wrong w/ a spool on the street. Rain or shine, doesn't matter about the spool. What does matter is the tires. Drag radials or street slicks are scary on wet pavement. Doesn't matter what differential you have if you're on tires w/ minimal tread and trying to drive on wet pavement.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Spool. Ok for the street? [Re: an8sec70cuda] #946895
03/12/11 08:28 PM
03/12/11 08:28 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
I went with a spool after my sure grip took a dump. I drive it on the street occasionally. I just make sure that I don't make any sharp turns around corners. It sort of comes naturally, after dragging 53' trailers around for the past 20 years.
Re: Spool. Ok for the street? [Re: ] #946896
03/12/11 08:39 PM
03/12/11 08:39 PM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
The Scamp had a spool in it. I got caught in the rain once and it made me a little nervous, but otherwise, I didn't mind it. It chirped the tires around corners, but it also made me drive the care carefully. I probably wouldn't drive a spool-equipped street car by choice again, but I'm certainly not against them.
My CJ-7 has Detroits front and rear, though I keep the front hubs unocked on the street. With a 7 inch lift, 35 inch tires, and a short wheelbase, it can be squirrelly in the rain, which I try to avoid. Otherwise, the occasional "bang" from the locker is the only time I notice it on the street. On the trail, they're worth their weight in gold.
Earning every penny of that moderator paycheck.
DBAP
