MEGA BLOCK ? #946588
03/08/11 09:33 PM
03/08/11 09:33 PM
Tennessee
steeldust Offline OP
Tennessee
The block came from RAYBRATTON and the numbers are 2468330 and it has a penstar on it and it is a 4.500 bore it has raised cam are they a gear set for it and it has 1,2,3,4,5 mains cross bolt is this a good block to build a 572. THANKS
Re: MEGA BLOCK ? [Re: steeldust] #946589
03/08/11 09:42 PM
03/08/11 09:42 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
with a 4.500 stroke it will be 572. no chain and gear that i know of must use a belt drive or a gear drive, also been said before check the main studs make shure they are ARP and not just the nuts, i recently bought a Alum version and going thru the same thing. but i'm going 4.750 stroke.
Re: MEGA BLOCK ? [Re: steeldust] #946590
03/08/11 09:43 PM
03/08/11 09:43 PM
Calgary Alberta
darksideracing Offline
Calgary Alberta
just order a gear drive for it....... raised cam
note the big cam / raised cam may gear drives come in 2 different sizes for the top gear you don't want that
used the are easy to find
Re: MEGA BLOCK ? [Re: Randy..] #946591
03/08/11 10:13 PM
03/08/11 10:13 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Randy
what would the cubic inches be 588 or bigger
1.39 9.85 - 137 mph
Re: MEGA BLOCK ? [Re: Ari440] #946592
03/08/11 10:21 PM
03/08/11 10:21 PM
I think that would be a 622"
Re: MEGA BLOCK ? [Re: Ari440] #946593
03/08/11 10:27 PM
03/08/11 10:27 PM
Tennessee
Tennessee
It is a 4.500 and a 4.750 it is 604 if i am right.Because a 4.500 bore and a 4.500 is a 572
Re: MEGA BLOCK ? [Re: ] #946594
03/08/11 10:52 PM
03/08/11 10:52 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The 4.5 bore x 4.625 is 604
Re: MEGA BLOCK ? [Re: rowin4] #946595
03/08/11 10:54 PM
03/08/11 10:54 PM
UK
602heavy Offline
602heavy  Offline
UK
4.562" bore/4.625 stroke = 604"
Re: MEGA BLOCK ? [Re: rowin4] #946596
03/08/11 10:55 PM
03/08/11 10:55 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Nope 4.5 bore with a 4.625 is a 588
4.5 x 4.75 is 604
Re: MEGA BLOCK ? [Re: Bob_Coomer] #946597
03/08/11 10:58 PM
03/08/11 10:58 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
4.5 x 4.75 is 604
how do you get a 622
are all these combos from 588 to 622 raised cam blocks
1.39 9.85 - 137 mph
Re: MEGA BLOCK ? [Re: Ari440] #946598
03/08/11 11:02 PM
03/08/11 11:02 PM
UK
602heavy Offline
602heavy  Offline
UK
Raised cam block allows clearance for the 4.75" stroke , last motor i had used a 4.562 bore with a 4.625 crank , was 604ci , the 4.562 bore that uses the 4.750 crank nets a 622ci.
Re: MEGA BLOCK ? [Re: Ari440] #946599
03/08/11 11:08 PM
03/08/11 11:08 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
4.5 x 4.75 is 604
Here is a formula
Bore X Bore X Stroke X 8 X .7854 = CI
4.5 x 4.5 x 4.625 x 8 x.7854 = 588CI
4.5 x 4.5 x 4.75 x 8 x.7854 = 604CI
Re: MEGA BLOCK ? [Re: Mpetros] #946600
03/08/11 11:11 PM
03/08/11 11:11 PM
UK
602heavy Offline
602heavy  Offline
UK
4.562 x 4.562 x 4.750 x .7854 x 8 = 622"
Re: MEGA BLOCK ? [Re: Bob_Coomer] #946601
03/08/11 11:12 PM
03/08/11 11:12 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
4.5 x 4.75 is 604
correct I own both
home of the
Sox and Martin Hemi Duster
Re: MEGA BLOCK ? [Re: HEMIFRED] #946602
03/08/11 11:16 PM
03/08/11 11:16 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
would a 622 ci be the biggest motor for a wedge/hemi
thank you guys
1.39 9.85 - 137 mph
Re: MEGA BLOCK ? [Re: Ari440] #946603
03/08/11 11:48 PM
03/08/11 11:48 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
thank you guys
4.562 bore/4.875 stroke=636ci ish (what my TS engines are)
4.562 bore/5 inch stroke=650ci ishci (Good clearencing in the block needed)
Re: MEGA BLOCK ? [Re: Ari440] #946604
03/09/11 02:57 AM
03/09/11 02:57 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
Randy
will be 604, think the biggest you can go with cast blocks is 654, 4.560 bore and 5.00 stroke can get more if you can go 4.600 bore.
Re: MEGA BLOCK ? [Re: HEMIFRED] #946605
03/09/11 12:29 PM
03/09/11 12:29 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
4.5 x 4.75 is 604
correct I own both
Fred....should we mention our friend in GA.?
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: MEGA BLOCK ? [Re: 23T Hemmee] #946606
03/09/11 03:19 PM
03/09/11 03:19 PM
Calgary Alberta
Calgary Alberta
If you guys need a calculator ........:
http://www.darkside.ca/tool.asp#9
