Re: Milodon's new pump cover
[Re: Keith Black®]
#943162
03/06/11 03:57 AM
03/06/11 03:57 AM
Posts: 27,483 So Cal
autoxcuda
So Cal
shame they haven't upgraded their remote filter pump cover. i need to replace mine but don't want to use the existing version. anybody else make a cover for that application?
dimensions would be useful, pump height, cover height.. I won't ever believe their statement again... "WILL FIT STD HEMI ENGINE MOUNTS"
I might be able borrow a pump and take pictures with it in a 68 Hemi Dart clone with hemi mounts.
I was told the pump will take stock oil pump covers too. So for you guys looking for a top of the line pump but a stock look, this will do the trick.
[Re: sasquatch]
#943163
03/06/11 04:17 AM
03/06/11 04:17 AM
Posts: 4,648 aotearoa
rebel
aotearoa
Ah look above at the other pictures posted. They make both side and rear entry under different part numbers. Todd
yes i see milodon do but i need a pump cover that is for a remote filter.
[Re: Dartwizer]
#943167
03/06/11 04:11 PM
03/06/11 04:11 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Any interest in a good Small Block oil pump?
There's all kinds of choices for the Big Block stuff. And all the cast iron SB stuff is controlled by one company now and only a small pickup can screw into it.
X2
I thought somebody was working on that and was posting something about it about a year ago on here? Keith
[Re: scottsgretch]
#943171
03/14/11 01:48 PM
03/14/11 01:48 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
I'm wondering if you can use the #21215 billet pump cover to plumb in a CANTON ACCUSUMP accumulator/pre-luber right at the pump.
Someone makes an adaptor that screws on where the filter goes with a tap on it to plumb in to. It may be Canton.
[Re: 70blackfish]
#943179
03/17/11 02:44 PM
03/17/11 02:44 PM
Posts: 7 AB Canada
Demon Guy
AB Canada
What ever became of that pump cover, tried to get one but no go.
71 Demon 451 SR All Motor
Chassis car 2475 w/driver
Best ET 9.08 @ 150.05, 4787 Corrected Alt
[Re: Demon Guy]
#943180
03/17/11 03:27 PM
03/17/11 03:27 PM
Posts: 10,023 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Nice of them to make this after I sent them a pic of the broken green gasket. They denied there was a problem. It blew in the lights at 153 mph, got sideways, but I got lucky and saved the car.
