Suddenly no heater blower/turn signals. Related? UPDATE
#942345
03/04/11 01:44 AM
03/04/11 01:44 AM
Posts: 4,280 Medford OR
FrankenScamp
Medford OR
This is on my dart... I'm gonna really look into it tomorrow but till then any ideas? Fuses are fine.... Didn't know if these two items are typically tied together electrically. Thanks as always....
Re: Suddenly no heater blower/turn signals. Related?
[Re: FrankenScamp]
#942346
03/04/11 10:35 AM
03/04/11 10:35 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Blower and TS are different circuits.Check that the blower has power to it.Do the TS light or just not flash?Might be the flasher.Rocky
Chrysler Firepower
[Re: therocks]
#942348
03/04/11 11:22 AM
03/04/11 11:22 AM
FrankenScamp
Medford OR
Not lights at all. I'll check for juice at the blower motor first and go from there.
I'm thinkin this is all just coincidence but wanted to ask to see if I was overlooking something. Thanks for the replies guys, I'll post my findings when I tear into it.
[Re: superwrench]
#942350
03/04/11 01:06 PM
03/04/11 01:06 PM
FrankenScamp
Medford OR
Wiggle the snot out of the key cylinder in the ignition switch,or look for a burnt wire from the switch.
Will do! Thanks
[Re: FrankenScamp]
#942351
03/04/11 02:01 PM
03/04/11 02:01 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
Wiggle or unplug & reconnect the bulk head harnesses at the firwall. I had stuff like this happen before & this was the cause. You may have to clean connectors too.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: scatpacktom]
#942353
03/04/11 03:11 PM
03/04/11 03:11 PM
therocks
Niles , Ohio
The flasher is easy to check also.One side should have power with key on.Rocky
Chrysler Firepower
[Re: therocks]
#942355
03/04/11 07:31 PM
03/04/11 07:31 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
Shouldn't both sides have power with the key on ? Its only when there's a load on the circuit that the bi-metal heats up and opens the circuit hence a flashing sequence .
[Re: 74fldart]
#942358
03/05/11 06:21 AM
03/05/11 06:21 AM
FrankenScamp
Medford OR
After all the wigglin of wires I did today and no leads yet makes me think about the ignition switch someone mentioned. I dug around in the column this mornin but nothing was obvious. No burn marks. The turn signal cam/switch has no juice but the hazard switch still works, as do the lights This is currently serving as my DD so I couldnt tear into it too bad this morning but come Monday I can totally disable it with confidence Thanks for all the help fellas, it means a lot!
[Re: FrankenScamp]
#942359
03/05/11 09:57 AM
03/05/11 09:57 AM
therocks
Niles , Ohio
The TS flasher and 4 way are 2 seperate ones.If the ts flasher is bad the swiych wont have power even though the 4 ways work.Rocky
Chrysler Firepower
Re: Suddenly no heater blower/turn signals. Related? UPDATE
[Re: FrankenScamp]
#942363
03/14/11 01:26 PM
03/14/11 01:26 PM
Posts: 4,253 State of Fascism
52savoy
State of Fascism
Sometimes the harness that feeds through the steering column gets freyed and shorts out. I would ohm both ends of the harness starting with the red wire. just my If that doesn't work do what SCATPACTOM says "Disconnect the battery and reconnect it. Your car needs to be rebooted" ..or checked for a "virus"
