V68 and V78 codes on 71 Challengers #942293
03/04/11 12:39 AM
03/04/11 12:39 AM
Iowa
71 SHAKR Offline OP
71 SHAKR  Offline OP
Iowa
I have noticed both of these codes on separate 71 Challengers recently and I am curious as to what factors determined if the car got a V68 or V78 stripe delete code??? I would appreciate any input!
Re: V68 and V78 codes on 71 Challengers [Re: 71 SHAKR] #942294
03/04/11 01:20 AM
03/04/11 01:20 AM
Alabama
BigMoneyLewis Offline
Alabama
The 3rd digit as an "8" designates delete . The V6X for example would be the longitudinal R/T stripe (in black) and the V7X is more of a pinstripe . V5X would be protective body side molding . V8X used on B bodies ,or V9X (70 Challenger) would be a bumblebee type (transverse) stripe .
Last digit is the color of course , I just used X(BLACK) as an example.
Greg
gregward@mchsi.com phone 256-852-0955
Re: V68 and V78 codes on 71 Challengers [Re: BigMoneyLewis] #942295
03/04/11 01:51 AM
03/04/11 01:51 AM
Iowa
71 SHAKR Offline OP
71 SHAKR  Offline OP
Iowa
Greg,
Thanks for posting and I understand what you are saying about the type and color of stripe. What I am trying to get clarified is if you get a V68 or V78 stripe code, you are still going to have a car with no stripe. Why did both codes get used for deleting a stripe on a car? That being said, are there other options that a car will/will not get to determine what stripe delete code to use on the car being built at the factory?
Re: V68 and V78 codes on 71 Challengers [Re: 71 SHAKR] #942296
03/04/11 02:53 AM
03/04/11 02:53 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
JH cars had the V7_ painted pin stripes STANDARD .... DELETED are coded V78.
JS cars had the V6_ "SPORT" side stripes STANDARD .... DELETED are coded V68.
Re: V68 and V78 codes on 71 Challengers [Re: 6bblgt] #942297
03/04/11 10:08 AM
03/04/11 10:08 AM
Iowa
71 SHAKR Offline OP
71 SHAKR  Offline OP
Iowa
I thought that might have been the case as one car was an RT and the other was a non-RT car.
Thanks 6bblgt!
Re: V68 and V78 codes on 71 Challengers [Re: 6bblgt] #942298
03/04/11 12:44 PM
03/04/11 12:44 PM
OWL
Culvers Offline
Culvers  Offline
OWL
JH cars with A66 had the V9_ painted transverse (bumblebee) STANDARD .... Deleted are coded V98
Culvers
Re: V68 and V78 codes on 71 Challengers [Re: Culvers] #942299
03/04/11 03:08 PM
03/04/11 03:08 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
No such thing in 1971 though.
Re: V68 and V78 codes on 71 Challengers [Re: KISSAlien] #942300
03/04/11 03:10 PM
03/04/11 03:10 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
True.
On another note, when you got a 340 JH 71 Challenger, that partial pinstripe would be standard correct? Just like any other JH car?
