Page 2 of 4 1 2 3 4
Re: Cruise Control on a '70 Challenger [Re: 70runner] #941362
03/03/11 10:33 AM
03/03/11 10:33 AM
cataclysm80 Offline
cataclysm80  Offline
The head, switch, and lettering is the same for all.
I Disagree with that statement. I've found 3 variations, and would be happy if anyone could tell me what years/cars they go with. (or maybe they were just made by a different vendor?)
See Pics...
This first picture is an E body lever. I was told it came out of a 70 Challenger.
Tav
Re: Cruise Control on a '70 Challenger [Re: cataclysm80] #941363
03/03/11 10:37 AM
03/03/11 10:37 AM
cataclysm80 Offline
cataclysm80  Offline
This is a B body lever. Notice there is a cutaway section for pressing the button on the end. The E body lever didn't have that.
Tav
Re: Cruise Control on a '70 Challenger [Re: cataclysm80] #941364
03/03/11 10:40 AM
03/03/11 10:40 AM
cataclysm80 Offline
cataclysm80  Offline
This is also a B body lever. Notice the addition of the "SET" lettering and arrow. I suspect this came after the levers without the lettering, haven't narrowed it down to a specific year yet. Any help appreciated.
Tav
Re: Cruise Control on a '70 Challenger [Re: EV2RTSE] #941365
03/03/11 10:47 AM
03/03/11 10:47 AM
cataclysm80 Offline
cataclysm80  Offline
If I'm not mistaken the wiring harness itself can be scavenged off of practically any car with factory cruise all the way through probably at least the mid 70's.
The wires color and where they go are the same, but there are sometimes differences in lengths. You might have to splice in a small piece to make it longer if you scavenge from another car.
I had an NOS B body harness that was just barely a little short for my E body.
Tav
Re: Cruise Control on a '70 Challenger [Re: Flying Banana] #941366
03/03/11 10:55 AM
03/03/11 10:55 AM
cataclysm80 Offline
cataclysm80  Offline
My '70 Challenger R/T w/auto in the console is coded for cruise control, but the steering column was replaced at some time in the past and the wiring and control stick are long gone. Is the stick a standard part across mopars, or specific to my car? If specific, is anyone reproducing this?
I'd love to hear more about your car. Do you still have any of the underhood cruise parts? The Servo bracket is E body specific and is tough to find, just like the turn lever.
The Servo itself, brake booster bracket, and throttle cable clamp can be scavenged from other cars. The throttle clamp is different for big block vs. small block. Big block left in photo, Small block right in photo.
Tav
Re: Cruise Control on a '70 Challenger [Re: mccannix] #941367
03/03/11 11:07 AM
03/03/11 11:07 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
As stated above 68-69 B-body is similar to E-body but has a shorter handle.
Both have small black button on end.
Terry this is the first time I've seen you post something I don't agree with... I've owned two factory cruise control Challengers, both had the larger button like posted in Tav's second picture above... Can't really see it well enough to tell which style handle it is but this car is coded for it & I bought it back in 74..
Re: Cruise Control on a '70 Challenger [Re: 1_WILD_RT] #941368
03/03/11 11:59 AM
03/03/11 11:59 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Here's the button style in my '71 Charger. My '73 Van has the shielded button with the word "SET" on the housing. Also, the lever shown above for C-bodies is actually for tilt columns only which are also used in '71 B-bodies. Non-tilt C-bodies use the same one as other cars except E-bodies.
Re: Cruise Control on a '70 Challenger [Re: cataclysm80] #941369
03/03/11 03:56 PM
03/03/11 03:56 PM
People's Republic of Kali
70runner Offline
70runner  Offline
I stand corrected - forgot about the notch and "SET" lettering. When I was collecting these, it seemed the notch appeared somewhere around the mid-70 model year. I never found any with the "SET" lettering prior to 70. These dates could vary of course.
This one came off a 70 Satellite, May build date (I usually kept the fender tags for parts w/o date codes):
Re: Cruise Control on a '70 Challenger [Re: 70runner] #941370
03/03/11 03:59 PM
03/03/11 03:59 PM
70runner Offline
70runner  Offline
This one off a 72 Plymouth S/W...
Re: Cruise Control on a '70 Challenger [Re: 70runner] #941371
03/03/11 04:27 PM
03/03/11 04:27 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
The problem is that you don't know if the switch was swapped out at some point. Chrysler would just supercede the early ones in parts because they still worked even if they looked different.
The '68-9 ones had different terminals on the end so they may have been unique.
Re: Cruise Control on a '70 Challenger [Re: NicksGarage] #941372
03/03/11 08:51 PM
03/03/11 08:51 PM
Minnesota
RROD Offline
RROD  Offline
Minnesota
Just curious. Did any 4-speed 70 E bodies have the cruise control option?
Re: Cruise Control on a '70 Challenger [Re: RROD] #941373
03/03/11 09:08 PM
03/03/11 09:08 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Cruise was N/A with manual trans or multi carb..
Re: Cruise Control on a '70 Challenger [Re: 1_WILD_RT] #941374
03/03/11 09:32 PM
03/03/11 09:32 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Randy
I could plead "brain fart" or "typo" but I will simply say you are correct and I was wrong, E-body button WAS larger
Re: Cruise Control on a '70 Challenger [Re: mccannix] #941375
03/03/11 09:39 PM
03/03/11 09:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Been there done that... It happens... I know for me it's gotta be CRS..
Re: Cruise Control on a '70 Challenger [Re: 1_WILD_RT] #941376
03/04/11 09:47 AM
03/04/11 09:47 AM
cataclysm80 Offline
cataclysm80  Offline
Also not available with Hemi
That said, I've seen cruise on an auto trans Cuda with a Hemi installed. The cruise throttle cable is Very close to hitting the valve cover. (owner may have bent the bracket a little for clearance) Also, you can't use the long Hemi power brake booster with the cruise. They take up the same space under the hood.
Also, After adding cruise to my 'Cuda, I also added a six pack. I'm not sure why the factory didn't want cruise with multi carb. I didn't have to do anything special to install mine, and it works like a dream.
On a Barracuda, the cruise wiring goes through the same spot on the firewall that was used for the 4 speed reverse dash light wire. For some reason I don't understand, Challengers seem to have used the spot that was used for road lamp wiring on 'Cudas. Both cars use the same cruise wiring harness, so it's odd to me that it would go through different spots on the firewall. I haven't seen cruise installed on a manual trans E body, but my cousin has cruise on his manual trans 2003 Mach 1 Mustang.
I'd be interested in learning more about which firewall holes were used for cruise on the other members cars here. Is it as I described?
Here's a picture for reference, so that we're all talking about the same holes.
(NOTE: in 71 the grommet for the 4 speed reverse dash light wire got smaller. Does anyone know if the cruise wiring grommet also got smaller, or did it stay the same as in 70.)
Tav
Re: Cruise Control on a '70 Challenger [Re: cataclysm80] #941377
05/08/11 05:29 PM
05/08/11 05:29 PM
cataclysm80 Offline
cataclysm80  Offline
Here's a pic of the cruise control 'Cuda I was talking about with the Hemi installed. To keep the cruise in the factory location, he couldn't use the Hemi brake booster setup.
Tav
Re: Cruise Control on a '70 Challenger [Re: cataclysm80] #941378
05/08/11 05:36 PM
05/08/11 05:36 PM
cataclysm80 Offline
cataclysm80  Offline
Not factory of coarse, but here's a hemi with the hemi brake booster setup, AND cruise. The cruise was intalled over where the fender tag would go, and I think the cruise throttle cable was routed slightly different so that it would reach.
Tav
Re: Cruise Control on a '70 Challenger [Re: cataclysm80] #941379
05/08/11 05:51 PM
05/08/11 05:51 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
on my 71 gtx, instead of having a twisting type indicator, mine has a sliding one? any reason?
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Cruise Control on a '70 Challenger [Re: mopars_1] #941380
05/08/11 06:00 PM
05/08/11 06:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I think Chrysler started using those around 74 so it has been changed assuming it is original.... Code on the fender tag would be N88
Re: Cruise Control on a '70 Challenger [Re: 1_WILD_RT] #941381
05/09/11 08:18 AM
05/09/11 08:18 AM
cataclysm80 Offline
cataclysm80  Offline
Either a previous owner added the cruise, or the original was damaged and replaced with this later version.
If it's original (N88 on fender tag), I'd be very interested to know where the cruise wiring grommet comes through the firewall. Pic if possible?
Tav
Page 2 of 4 1 2 3 4
