Re: Nice weight savings!
[Re: 408strokerdart]
#941217
03/02/11 10:58 PM
03/02/11 10:58 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
2 red top Optima batteries (96 lbs)
Wow.. I didnt know it was that much.. Thanks for sharing the info..
[Re: Jeepmon]
#941218
03/02/11 11:04 PM
03/02/11 11:04 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
how heavy were you last season?
thats still amazing you lost that much with all the bars you added
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: John Burdine]
#941224
03/03/11 10:13 AM
03/03/11 10:13 AM
sixpackgut
Charleston
should i assume that weight is with you in the car? that is impressive
[Re: DavidDean]
#941225
03/03/11 10:14 AM
03/03/11 10:14 AM
Posts: 3,456 Out West
408strokerdart
Out West
Very intresting post,thanks. Are you trying to run the 5.80 class at Crandall?
Yes, that is exactly what I'm trying to do.
#941228
03/03/11 12:28 PM
03/03/11 12:28 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I didn't realize your car was that light to begin with. you are right it looks a lot heavier than it is. I've been trying all winter to get my small block car down to 2800lbs with driver, but I don't know if I've done it or not.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#941229
03/03/11 04:10 PM
03/03/11 04:10 PM
408strokerdart
Out West
I really didn't realize all of the different places that I could remove weight. Just have to justify the cost to reduce the weight vs. simply upping the HP. I decided to just lighten the car since that will pay future dividends with less parts breakage. I refuse to sacrifice the original outward appearance of the car though.
#941230
03/03/11 07:37 PM
03/03/11 07:37 PM
Posts: 437 south central pa
bdaz smblk
south central pa
Your doing good.My car has a alum motor in it and is still 3,120.But I can't give up the stock interior or the stock gauges.And I can't afford a chromoly cage so I guess I'll have to deal with it.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: fishy340]
#941232
03/03/11 10:05 PM
03/03/11 10:05 PM
408strokerdart
Out West
brian thats awesome,im not sure what kind of front end u have,but i lost well over 100lbs in my cuda by using rms alterkation,plus added tons of adjustability
Fabbed moly k-frame, fabbed front struts, R&P steering. Can't get much lighter there.
[Re: Stroker Scamp]
#941234
03/03/11 10:52 PM
03/03/11 10:52 PM
408strokerdart
Out West
I was 2840 last year. Other weight savings is coming from:
More efficient wiring light weight headlights removal of the original trans crossmember removal of all of the structure under the dash that used to mount the brake pedal/master cyl lightened the dash add racepak and loose all of the gauges/shift light/fuel isolator lexan windshield/side windows/remove regulators removed every unnecessary tab/bracket/piece of metal (4 lbs in a bucket)
I am sure there are other places I lost weight. Not everything I mentioned has been done yet either. I started out the winter with a goal of making the car cert 25.5 and to reduce the weight to 2700 lbs without jacking up the overall look of my car. BTW, it still has the factory interior door panels, headliner and will be carpeted.
did you weigh your regulators, specificaly the rear?
I didn't weight the rear regulators. The last year car weight was without those since I removed those early last year. I am going to do the pass side window fixed in place without any track and I am going to do the driver side window so it rolls up and down (fasten with seat belt like old super stock) since I can't even think how big of a PITA it would be to load and unload the car without being able to steer it.
[Re: DavidDean]
#941238
03/04/11 10:16 AM
03/04/11 10:16 AM
408strokerdart
Out West
Were you at Crandall for the $3K bracket race just recently?
[Re: Jeepmon]
#941241
03/06/11 02:17 PM
03/06/11 02:17 PM
408strokerdart
Out West
Guess I should get the scale out before I go spewing out numbers. I scaled the old batteries yesterday so I could take inventory and they were 39 lbs for one and 40 lbs for the other. So they are 79 lbs and not the 96 lbs I previously stated.
#941244
03/07/11 09:38 PM
03/07/11 09:38 PM
Posts: 6,151 Melbourne , Australia
LA360
A friend went that extra step with weight savings and dropped around 30 lbs himself!
I have a 68 Valiant where the original builder swiss cheesed most of the panels. The hood was quite light, on par with some of the fibre glass stuff I have seen.
Alan Jones
[Re: LA360]
#941251
03/08/11 10:07 AM
03/08/11 10:07 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Ugh... dont remind me... Since the last time i drove my car i've gained 50lbs... And i'm obsessed with weight-reduction. 50lbs is gonna hurt.
