Re: Modern Cylinder Head
[Re: Kiddart]
#940137
02/28/11 08:30 PM
02/28/11 08:30 PM
Posts: 3,210 robin hood country
deaks
robin hood country
A very busy guy but well worth persevering from a quality and performance perspective. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Twin Turbo Mower]
#940141
02/28/11 09:42 PM
02/28/11 09:42 PM
The Million Dollar Question? How long does he take?
#940142
02/28/11 09:51 PM
02/28/11 09:51 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
^^^^ Just depends. On numerous occasions for me it was about 6-8 weeks. Well worth the wait. He does top notch stuff, but he is human, stuff can happen. I had a issue with a set of 440-1 heads he machined. I called him after we figured out what the problem was, just a simple mistake. The man sent me cash in 3 days to cover the cost to correct the mistake which covered the work and gas money to correct, which was cheaper and simpler to fix via sending them back and waiting. What can I say, he has since sold me several sets of heads, cnc ported a set of hemi heads, exchanged parts after I went I diff direction. The man is top notch.. I will go back next time also.... Top notch service, and actually cares after the stuff leaves the door, so customer service is top notch also. I give him 5 Stars.... Yes he's busy, and hard to catch some time on the phone, PM here and he will get back to you. Bob Coomer
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
#940143
02/28/11 09:53 PM
02/28/11 09:53 PM
Posts: 3,887 Smyrna, South Carolina
STEFF
My Gen 3 Hemi heads......dropped off, CNC ported, valve jobbed, decked & assembled, picked up.......10 days.
[Re: STEFF]
#940144
02/28/11 09:59 PM
02/28/11 09:59 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
spent 6k on his heads no complaimt here
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#940145
02/28/11 10:01 PM
02/28/11 10:01 PM
Posts: 1,573 Michigan
Kiddart
i want a a stage 3 head job complete does anyone know the cost for a small block
Thank you Kiddart
[Re: Kiddart]
#940147
02/28/11 10:09 PM
02/28/11 10:09 PM
Bob_Coomer
Rock Springs
whats a stage III port job? I can tell you he might NOT have a clue what your talking about or want. Im not sure he hand ports much any more, maybe for experimental or cnc program creation. If I was wanting good work but not full CNC port work, why not contact Dewayne Porter on this board.. another great guy with great service. I suggest you hit the tech archive and do some research, it will explain what you might want to know about diff levels of port work. Which can and will be totally diff from shop to shop.. I know Indy's Super Mod port work on a set of -1's is nothing more than a gasket match on the openings and maybe some bowl blending... About $750-$800 worth of work one could accomplish in a hour or two doing all 16 ports at home.
[Re: Labratt]
#940149
03/01/11 01:41 AM
03/01/11 01:41 AM
Posts: 614 Michigan
Get-X
Jeff is the man CNC'd my St.V Hemi heads and will go thru my Hemi99 heads if I continue with it. He's a great guy and does great work.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: HEMIFRED]
#940150
03/01/11 01:45 AM
03/01/11 01:45 AM
Posts: 19,543 Las Vegas
Al_Alguire
Las Vegas
Jeff at Modern has always done me right..
[Re: Bob_Coomer]
#940151
03/01/11 01:40 PM
03/01/11 01:40 PM
Kiddart
everyone seems to have a stage 1 thru stage 3 listed as servise on the web sites. Stage 3 would be a complete port and polish head job normally runs around 800 to 1000 bucks
Thank you Kiddart
[Re: Kiddart]
#940152
03/01/11 01:46 PM
03/01/11 01:46 PM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
Jeff CNC'd my hemi heads 5 years ago. NICE work.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
