Page 2 of 3 1 2 3
Re: 72 Challenger Project [Re: patosmith] #938086
01/01/12 02:46 PM
01/01/12 02:46 PM
Spanaway, Washington State
P
patosmith Offline OP
P
Quarter panel in place.
Re: 72 Challenger Project [Re: patosmith] #938087
01/01/12 02:49 PM
01/01/12 02:49 PM
P
P
Now let's do the other side.
Re: 72 Challenger Project [Re: patosmith] #938088
01/01/12 02:52 PM
01/01/12 02:52 PM
P
P
A rusted out spot I fixed before the quarter was installed.
The "fixed" picture file size is too large to post.
I cut out all of the bad stuff, welded in new, Treated, primered and painted.
Re: 72 Challenger Project [Re: patosmith] #938089
01/01/12 03:03 PM
01/01/12 03:03 PM
P
P
The edge of the tail piece was pretty sad.
I better fix that too.
Re: 72 Challenger Project [Re: patosmith] #938090
01/01/12 03:06 PM
01/01/12 03:06 PM
P
P
New piece being formed and fitted.
Once everything was welded up it was primered with weld thru primer.
Re: 72 Challenger Project [Re: patosmith] #938091
01/01/12 03:18 PM
01/01/12 03:18 PM
P
P
Done. ready for the quarter panel.
Re: 72 Challenger Project [Re: patosmith] #938092
01/01/12 03:22 PM
01/01/12 03:22 PM
P
P
Inside of quarter panel was primered, painted and the perimeter was hit with weld thru primer. This was done to the driver's side too.
This is an AMD part.
Re: 72 Challenger Project [Re: patosmith] #938093
01/01/12 03:28 PM
01/01/12 03:28 PM
P
P
The quarter panels I purchased from AMD.
This quarter panel had to be tweeked a couple of times before it would fit correctly. I had trouble in the area where it meets the rear window and surrounding area.
The other quarter fit without much work.
I think the AMD pieces are great.
Re: 72 Challenger Project [Re: patosmith] #938094
01/01/12 03:39 PM
01/01/12 03:39 PM
P
P
Let's move on to the roof...
I had hoped that I could treat and repair any rust damage without removing the roof.
Re: 72 Challenger Project [Re: patosmith] #938095
01/01/12 03:49 PM
01/01/12 03:49 PM
P
P
Previously I thought I could fix the rusted out metal here without removing the roof.
After seeing more rust while working on the quarter panels I knew I had best remove the roof. Luckily I did. I had rust starting to come thru the roof on the passenger side in 2 spots just above the door and windshield. When I removed the lead from where the roof and passenger side quarter panel meet a spot blew out just under the lead about the size of a half dollar coin.
Re: 72 Challenger Project [Re: patosmith] #938096
01/01/12 03:52 PM
01/01/12 03:52 PM
P
P
Another shot of the driver side.
Re: 72 Challenger Project [Re: patosmith] #938097
01/01/12 03:56 PM
01/01/12 03:56 PM
P
P
They don't repop the structure pieces that go from front to back yet. I had to take the pieces down to a local restoration shop to have them make the pieces for me. I could have done it if I had the proper shop equipment. They did a great job. The pieces fit with minimal hassle.
Re: 72 Challenger Project [Re: patosmith] #938098
01/01/12 04:07 PM
01/01/12 04:07 PM
P
P
I had a little repair work to do before I weld in the new pieces.
Re: 72 Challenger Project [Re: patosmith] #938099
01/01/12 04:13 PM
01/01/12 04:13 PM
P
P
Tacking in a patch. It was then welded, smoothed, treated and primered.
Re: 72 Challenger Project [Re: patosmith] #938100
01/01/12 04:18 PM
01/01/12 04:18 PM
P
P
Patch completed and the new pieces welded in place. Better than new since I treated and primered everything inside and out.
The passenger side was not this bad so it will not be this involved.
Kind of strange since the roof was rusting out on the passenger side.
More to come.
I will be ordering the roof and drip rails from AMD in the next month or so. I will post that adventure as it happens!
Re: 72 Challenger Project [Re: patosmith] #938101
01/02/12 01:30 PM
01/02/12 01:30 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Nice job! Looking forward to seeing the rest of this build as it progresses.
Re: 72 Challenger Project [Re: JDMopar] #938102
01/13/12 11:04 AM
01/13/12 11:04 AM
Chicago
rocksmopar Offline
rocksmopar  Offline
Chicago
You are making metal replacement look easy!
Nice Job
Looking for affordable 72-74 Cuda parts
Re: 72 Challenger Project [Re: rocksmopar] #938103
01/15/12 09:37 PM
01/15/12 09:37 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
you rock
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: 72 Challenger Project [Re: aspenrt360] #938104
04/15/12 12:55 PM
04/15/12 12:55 PM
P
P
Test fitting the new roof I purchased from AMD.
Re: 72 Challenger Project [Re: patosmith] #938105
04/15/12 01:02 PM
04/15/12 01:02 PM
P
P
Took a little doing to position the roof rails in the right spot but I took my time and the roof installation turned out great without much of a problem.
I plan to use lead where the roof and quarters meet.
Page 2 of 3 1 2 3
