Re: SixPack Aircleaner Spacer [Re: Mr.Yuck] #934658
02/22/11 07:58 PM
02/22/11 07:58 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
I have 1/2" spacers under my carbs because the center one has meth jets in it. Why does your lid hit the fuel line? did you install it upside down? Mine drops way down and isn't even close. If you raise the air cleaner you are going to put it into the hood. I had zero room w/ my stock hood so I had to go get a glass cowl hood.
Like I said the motor is a low deck stroker with the airgrabber
Re: SixPack Aircleaner Spacer [Re: dart4forte] #934659
02/22/11 08:54 PM
02/22/11 08:54 PM
NY
W
WICKD6PK Offline
WICKD6PK  Offline
W
NY
promax makes a 6pk fuel line that isnt a "rail" type that may work for the fuel lines..but the dist i dunno.I had the same prob i used promaxs 6 pk line and 1" spacers under the carbs but i am using a 6 pk hood as well
Re: SixPack Aircleaner Spacer [Re: WICKD6PK] #934660
02/22/11 10:43 PM
02/22/11 10:43 PM
tx
craigsmytcudas Offline
tx
I just went to home depot and bought 1x30 aluminum strap and wraped it around a plywood buck pilled from a gasket then welded the ends ,less than 2hrs worked great .
Re: SixPack Aircleaner Spacer [Re: WICKD6PK] #934661
02/23/11 01:27 PM
02/23/11 01:27 PM
Mesa, Arizona
Mesa, Arizona
Thanks. Took a look at that and it may interfere with the linkage. The fuel inlet and linkage are all on the same side.
Re: SixPack Aircleaner Spacer [Re: dart4forte] #934662
02/23/11 08:59 PM
02/23/11 08:59 PM
NY
W
WICKD6PK Offline
WICKD6PK  Offline
W
NY
do ya have a pic of the side where the linkage and rail is? the line from promax hugs the carbs pretty close
