Re: what do you use to block off heater hose fitting on w.p [Re: 602heavy] #933948
02/22/11 08:57 AM
02/22/11 08:57 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Might be missing something here cos i can't remember .................blocking those heater hose outlets won't allow any water to flow through block & heads until thermostat opens , this is the reason for the 'loop' , fine to plug em off if you don't run a thermostat (or drill stat)........block temps will be a lot higher than temps @ water pump neck , with no water flowing through block & heads heads 'hot spots' will cause block scaling & worse still can crack when thermostat opens.
I don't know if that's true or not, but where does the water flow? it's not going through the radiator, so even then, when the thermostat opens, you'll still get a rush of cold water from the radiator flowing into the block and heads.
**Photobucket sucks**
Re: what do you use to block off heater hose fitting on w.p [Re: mcmopars] #933949
02/22/11 08:59 AM
02/22/11 08:59 AM
for those integral nipples the black neoprene caps from the "help" section at your parts house & a hose clamp is the only option & last a long time. A bit of gasket cement & recheck tightness once in a great while & you're good
Re: what do you use to block off heater hose fitting on w.p [Re: 70Cuda383] #933950
02/22/11 11:02 AM
02/22/11 11:02 AM
UK
602heavy Offline
602heavy  Offline
UK
Correct , water won't flow until stat opens when plugging outlets , block temps can reach well over 250 degrees , fitting the 'loop' insures water gets circulated round block & heads when stat is closed , this is the reason for some of these cracked blocks.
Re: what do you use to block off heater hose fitting on w.p [Re: AndyF] #933951
02/22/11 11:14 AM
02/22/11 11:14 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
On a small block the nipple doesn't always come out. Most small block water pumps have a cast nipple.
interesting... didn't know that!
then:
some end caps like this have an internal... mmm dunno how it call it... stud maybe ? tit ? made on same rubber what fits inside the pipe. Renaults use to use these
Re: what do you use to block off heater hose fitting on w.p [Re: NachoRT74] #933952
02/22/11 11:50 AM
02/22/11 11:50 AM
scratchnfotraction Offline
on a sb you can block the intake nipple and wp outlet nipple for the heater core with no ill effects
the bigger by-pass hose from wp to intake flows water while the t-stat is closed,so no cold water hitting hot spots,it warms up evenly
it also helps keep the wp from cavitating while the stat is closed
some do block it,and running with no stat,it would be fine to block both
