Sheet metal interiors (back half) #932405
02/19/11 04:50 PM
02/19/11 04:50 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
I am going to keep my challenger all steel. Does anyone weld in tubs and or the sheet metal or is all of it riveted? This car will be driven on the street. Any pics would be appreciated.
Thanks,
Josh
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: Sheet metal interiors (back half) [Re: Jambbii] #932406
02/19/11 07:24 PM
02/19/11 07:24 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
www.bigwigracecars.com for nice tin work
Depends on what you are going after ,
Mini tub ?
Big tubs ?
Re: Sheet metal interiors (back half) [Re: bigdad] #932407
02/20/11 10:10 AM
02/20/11 10:10 AM
1/2hr south of Ocala, FL
JCRVETTE Offline
JCRVETTE  Offline
Being welded in makes it substantially stronger, whether stitched or spot welded (stitch preferred), although if the welds aren't "pretty" and you don't intend to use carpet, it could be a little unsightly. We usually weld sheetmetal and rivet aluminum. One thing to consider, if it will be street driven, is over the years the constant flexing (however slight that may be) from driving over uneven surfaces, cornering, ect., will eventually shear some of the rivets off. You can rivet a few panels you think you may want to remove/replace in the future. If you weld the tubs in, I would caulk the seam between the 1/4 and tub.
Re: Sheet metal interiors (back half) [Re: JCRVETTE] #932408
02/20/11 02:55 PM
02/20/11 02:55 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
Car is back halved right now. I am going to carpet over everything (besides trunk). I was thinking stitch welding and using seam sealer like you said JCRVETTE.
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Sheet metal interiors (back half) [Re: Jambbii] #932409
02/20/11 11:01 PM
02/20/11 11:01 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I seen a car that was back halfed last year that the sheet steel was welded in. The guy had every tack about 2" apart . It looked neat in one way and crapy in another. The welds were neat not burned thru or chicken drops. I'd go with large headed rivets even if you had to re-drill and replace once in awhile, or weld and carpet.
Re: Sheet metal interiors (back half) [Re: Jambbii] #932410
02/20/11 11:52 PM
02/20/11 11:52 PM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
I did all my tin work with sheet metal and welded everything.
Re: Sheet metal interiors (back half) [Re: Viper469] #932411
02/21/11 12:00 AM
02/21/11 12:00 AM
rowin4 Offline
rowin4  Offline
So did you paint it or carpet? Ya did a real nice detailed job.
Re: Sheet metal interiors (back half) [Re: rowin4] #932412
02/21/11 12:25 AM
02/21/11 12:25 AM
Re: Sheet metal interiors (back half) [Re: rowin4] #932413
02/21/11 02:29 AM
02/21/11 02:29 AM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
Thanks, I carpeted the inside and painted everything else.
To make the panel under my fuel cell removable i drilled and tapped the holes , then used allen head bolts.
Re: Sheet metal interiors (back half) [Re: Viper469] #932414
02/21/11 07:46 AM
02/21/11 07:46 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Man, I have to give credit where due.
That is some beautiful work.
Re: Sheet metal interiors (back half) [Re: POS Dakota] #932415
02/21/11 09:30 AM
02/21/11 09:30 AM
JCRVETTE Offline
JCRVETTE  Offline
X2, and superfreak also
Re: Sheet metal interiors (back half) [Re: JCRVETTE] #932416
02/21/11 12:30 PM
02/21/11 12:30 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
Nice pics! You guys have any downside to welding? What seam sealer did you guys use?
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Sheet metal interiors (back half) [Re: Jambbii] #932417
02/21/11 01:15 PM
02/21/11 01:15 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
It's more than likely Sikaflex
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Sheet metal interiors (back half) [Re: Jambbii] #932418
02/21/11 08:34 PM
02/21/11 08:34 PM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
I used 3m automix seamsealer.
Re: Sheet metal interiors (back half) [Re: Viper469] #932419
02/21/11 09:53 PM
02/21/11 09:53 PM
I used sikaflex ( black ) great stuff. I tried a tube of that 3m product and had to wait 4-5 days for it to dry up and my shop is heated.
Re: Sheet metal interiors (back half) [Re: ] #932420
02/21/11 10:27 PM
02/21/11 10:27 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
