Re: Obtaining quench in a slant 6?
[Re: polkat]
#931548
03/03/11 11:38 PM
03/03/11 11:38 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
You may want to measure a chamber, I'm pretty sure a +.140" deck height will be smashing the piston into the head. Most positive deck height I know of anyone getting away with was +.020", and the chambers had to be ground out for that. With that much of the piston out of the deck you may be very close to popping the top ring out too.
[Re: ahy]
#931550
03/04/11 02:05 AM
03/04/11 02:05 AM
Posts: 1,202 California
polkat
mopar addict
mopar addict
California
ahy, interesting idea, but if 225 rods were used, it would call for a piston with a 1.921" CH, and that's just too much above the pin, for me anyway.
My understanding over at the Slant 6 site was that the combustion chamber floor sat an average of .200" above the flat face of the head (as would be seen from underneight). The floor then climbs up toward the valves and plug area. If true, then a piston top .147" out of the hole would not hit any part of the combustion chamber, particularly with a .020" head gasket between them.
Since the head simply cannot be milled enough to create a closed chamber, positive piston deck height is the only possible way to acheive real quench.
Yes, the KB 268 with 198 rods would be perfect if it had just a tad more CH. The 268's have 1.594" CH, but for usable quench with 225 rods, a piston with a CH of about 1.614" or more is needed.
Understand again that I have not measured any of this yet. I'm just speculating on how to approach it. Guess I'll do some piston research as well.
[Re: polkat]
#931551
03/04/11 08:13 AM
03/04/11 08:13 AM
slantzilla
Park Forest, IL
The chamber is not the same diameter as the piston. Look up an empty bore with a head on and you will see the chamber overhanging. The piston will hit it.
[Re: slantzilla]
#931552
03/04/11 09:25 AM
03/04/11 09:25 AM
RapidRobert
In the old days b 4 closed chamber heads were more avail guys (w 906's) welded up the OC recess then milled it flat & no reason it couldn't b done to a slant head if there's no piston that will get r done
