Page 1 of 3 1 2 3
Heres some pics of the Dakota Project #929817
02/15/11 08:47 PM
02/15/11 08:47 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
The cage you hardly can tell is there. This will change a little once the door bars are installed. I wait til the last minute to do these as they are easy but get in the way while building.
Leon
Re: Heres some pics of the Dakota Project [Re: Leon441] #929818
02/15/11 08:49 PM
02/15/11 08:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pic isnt working Leon
Re: Heres some pics of the Dakota Project [Re: MR_P_BODY] #929819
02/15/11 09:53 PM
02/15/11 09:53 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Here is the dash bar. I notched the steering column mount. The bar is welded to the body on both ends and into the steering column mount. Try tearing this one out.
Re: Heres some pics of the Dakota Project [Re: Leon441] #929820
02/15/11 09:59 PM
02/15/11 09:59 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Here is the A-pilar/halo and main hoop. There is no way to ever change a headliner now. The tallest of drivers like me fit.
Re: Heres some pics of the Dakota Project [Re: Leon441] #929821
02/15/11 10:04 PM
02/15/11 10:04 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Here is my favorite view from the drivers seat. Full view through every window. No intrusions.
Re: Heres some pics of the Dakota Project [Re: Leon441] #929822
02/15/11 10:08 PM
02/15/11 10:08 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Here is the second stage of the project. Removed the factory spring hangers. Then made a front spring hanger assembly to weld into the frame. Here is a pic of the hanger with support plate bridging the frame rail.
Re: Heres some pics of the Dakota Project [Re: Leon441] #929823
02/15/11 10:08 PM
02/15/11 10:08 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
nice work
Re: Heres some pics of the Dakota Project [Re: one bad fish] #929824
02/15/11 10:12 PM
02/15/11 10:12 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Is is the same spring hanger PS viewed from outside of framerail. The truck has split mono's and cal tracks.
Re: Heres some pics of the Dakota Project [Re: Leon441] #929825
02/15/11 10:16 PM
02/15/11 10:16 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Really struggled with what I wanted to do here. Could have simply cut out and replaced with tubing. But, said anybody can do that. The spare tire mount, the way it is made really puts some regity in the frame. So I lightened it. LOL
Re: Heres some pics of the Dakota Project [Re: Leon441] #929826
02/15/11 10:20 PM
02/15/11 10:20 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
This is a store bought peice from AFCO. It replaced the swing style hanger. Main reason for using this was to raise the leaf up 2" to match the front.
Re: Heres some pics of the Dakota Project [Re: Leon441] #929827
02/15/11 10:21 PM
02/15/11 10:21 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Why a truck Leon?
Re: Heres some pics of the Dakota Project [Re: Leon441] #929828
02/15/11 10:22 PM
02/15/11 10:22 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
are you building this for any particular class? nice work
Re: Heres some pics of the Dakota Project [Re: Leon441] #929829
02/15/11 10:26 PM
02/15/11 10:26 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Here is a pic of the Dana 60 housing. It will be filled with Strange 35 spline axles with 5/8 studs and a spool.
Yes, this is a set of Santhuff double adjustable shocks the owner stole. They are just hanging on some bolts right now awaiting the lower mounts being cut at a lazer shop. I plan to weld the mount to the caltrac lower spring plate. Then if for some reason we upgrade the suspension or want to build another car this is the last set of rear shocks he should ever need to buy. OVERKILL absolutely. But, isn't that what racing is all about.
Re: Heres some pics of the Dakota Project [Re: Leon441] #929830
02/15/11 10:26 PM
02/15/11 10:26 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Looking good...Keep the pics coming...Want to build another cage....LOL
I modded my spare tire carrier too.
Here's my shock set up before I installed the Monoleafs and Caltracs.
http://www.nmbuilder.com/Shocks_5a.jpg
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Heres some pics of the Dakota Project [Re: Hot 340] #929831
02/15/11 10:28 PM
02/15/11 10:28 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Why a truck Leon?
Fast trucks surprise people...
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Heres some pics of the Dakota Project [Re: Hot 340] #929832
02/15/11 10:28 PM
02/15/11 10:28 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Why a truck Leon?
Because the man with the Benjamins wants one.
NOT MY TRUCK
Re: Heres some pics of the Dakota Project [Re: Leon441] #929833
02/15/11 10:34 PM
02/15/11 10:34 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
NOT MY TRUCK
OK!
Re: Heres some pics of the Dakota Project [Re: sixpackgut] #929834
02/15/11 10:35 PM
02/15/11 10:35 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
The customer is a big fan of the Dakota RT club class. They are very perculiar about their street truck. They realized they did not want to butcher it. SO they found another truck regular cab to be lighter. I would have liked the room of an extended cab but they are much heavier. Now they are getting into more reality as the days go by. We would like to race at some Mopar events simply because that is were they got the idea to start with. I have been asked to drive as the intended driver is working 7 days a week and getting married. He will not have the pateince to sort this thing out. I would like to run it in a local 6.95 class. I won the 5.95 season points last year and would like to run this in the other class until they want to take over. Then I will bring my car back out if I still have transmissions and engine. I am currently trying to sell. I think this stock suspension stuff is neater to drive as you actually have to drive. But, this is going to be a lot more trick than any stock suspension I ever fooled with.
Leon
Re: Heres some pics of the Dakota Project [Re: Leon441] #929835
02/15/11 10:36 PM
02/15/11 10:36 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Why a truck Leon?
NOT MY TRUCK
The man with the Benjamins is gonna have a nice truck...
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Heres some pics of the Dakota Project [Re: Leon441] #929836
02/15/11 10:38 PM
02/15/11 10:38 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Very nice. One of the cleanest cage installs I've seen.
Randy
Page 1 of 3 1 2 3
