Page 2 of 5 1 2 3 4 5
Re: fixin' up old heads [Re: kilroy] #929176
02/15/11 01:00 AM
02/15/11 01:00 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Great post Dwayne...
rvoyles
Re: fixin' up old heads [Re: Quicksilver440] #929177
02/15/11 01:31 AM
02/15/11 01:31 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Mr. Porter should post the amount of time he has in those, as well as the final tally on the bill, to reinforce the fact, that unless you are doing a resto type deal, aftermarket heads, are just better, as well as cheaper in the long run.
Monte
Re: fixin' up old heads [Re: Monte_Smith] #929178
02/15/11 02:13 AM
02/15/11 02:13 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Good lookin' work there. Did you stick with 3/8 stems or run some 11/32 chevrolet stuff?
Re: fixin' up old heads [Re: Monte_Smith] #929179
02/15/11 09:11 AM
02/15/11 09:11 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Monte
X2
Re: fixin' up old heads [Re: Monte_Smith] #929180
02/15/11 10:21 AM
02/15/11 10:21 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I agree 100% as does Dwayne I am sure. I am pretty sure he will be posting more info on this topic. I know the job he is showing,as he and I have spoke of it, and yes, the guy wanted the original J heads.Is it " cost effective" for an old J or X head anymore. I think not. You'll see why later.Also,Dwayne will be carving up a set of old J heads I have and we are going to see what happens at that point with cost, practicality and performance. I think his results will be interesting on that one.
Dwayne and I were working on some small joint projects which dealt with just this situation. Is it WORTH fixing old heads anymore? I will let him answer, but I think it will become very obvious when he starts posting some more information. I wanted to see where practicality and performance starts and stops whith a typical street driven small block performance engine. Its pretty interesting once you dig deep into it. Anyhow, this is Dwaynes post, so we'll let him do his thing.
BTW. I have been involved in and around drag racing all my life, in many different venues, ownerships, partners, cars, race tracks etc.
I consider Dwayne a very good personal friend, and a business " partner", as we do a fair share together. I can tell you this, He is one of the most straight up, professional and talented cylinder head/engine guys you will ever meet. You get what you pay for, and Dwaynes work is some of the best out there. I highly recommend him. . Dont call him if you dont want to hear the truth, or the right way to do things. If you want to cut corners, he's not your guy. If you want it done right, then you'll be in good hands.
( since this was unsolicited, I sure hope I didnt make him blush... )
RIP Monte Smith
Re: fixin' up old heads [Re: CompWedgeEngines] #929181
02/15/11 11:40 AM
02/15/11 11:40 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Speaking as a vastly underqualified person of this forum........
and an owner of several sets of X & J heads.
This is a great thread!
As I read the threads on the "Can I use my aftermarket heads OOTB?", I've got to believe that getting those mass produced latest offerings up to race standards is NOT for free. Touching up the valve job, correct application valve springs & retainers, correcting valve guide tolerances, fixing exhaust valve seat inserts and whatever other horror stories...........
Without going into what it costs for me to get a set here locally freshened.....I'm just wondering how much, on average, most racers pay IN TOTAL for a set of ready-to-run aftermarket heads.
I know when it comes to "Quench" and using a better port & combustion chamber design it's worth the $$$.
I understand if you want to go real fast..........then you start with a "clean sheet" engine build....open wallet wide if you want the big HP.
It just seems like there may be a valid case where a budget minded bracket racer street/strip guy could justify using the old iron.
Re: fixin' up old heads [Re: Dean_Kuzluzski] #929182
02/15/11 11:47 AM
02/15/11 11:47 AM
an8sec70cuda Offline
Great thread and goes to show why some of these "rebuilt" engines run so poorly. I'm just glad to see Dwayne back posting some good stuff.
BTW Dwayne, I'll be calling you soon for a cam for my '71 340 Demon.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: fixin' up old heads [Re: Dean_Kuzluzski] #929183
02/15/11 01:05 PM
02/15/11 01:05 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Even if you did buy the new heads and they needed the valve job touched up, or maybe better springs, or maybe a little bowl blending.............in the end, they will still usually cost less than bringing a "used up" set of J heads back to life. Now you can short cut anything and save dollars, but I am talking about doing it right. Just like the pics posted. Many would have hammered new guides in there, ground the seats, put new valves in and called it a day..... although fresh, the heads still would have been junk. Doing it "right" and doing it "cheap" can never be one in the same.
Monte
Re: fixin' up old heads [Re: Monte_Smith] #929184
02/15/11 03:12 PM
02/15/11 03:12 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Thanks Dwayne for the post as I also enjoy reading about some of the older stuff and making it better. There is a real good post (24 pages) on the flow bench forum were a member played with a small block mopar head. If anyone is interested here's the link.
http://www.flowbenchtech.com/forum/viewtopic.php?f=25&t=54
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: fixin' up old heads [Re: pittsburghracer] #929185
02/15/11 03:25 PM
02/15/11 03:25 PM
Central Valley, CA.
Central Valley, CA.
Another issue is that you can do all this work to an old cast iron head and then it is still prone to cracking.....much less likely to happen on most of the aluminum heads out there.
Re: fixin' up old heads [Re: Quicksilver440] #929186
02/15/11 03:45 PM
02/15/11 03:45 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Thank You for taking YOUR time and posting this,Dwayne! VERY good info...as usual! Still LOVIN' that SQ cam you spec'd out for me a few yrs. ago!
Re: fixin' up old heads [Re: Labratt] #929187
02/15/11 05:33 PM
02/15/11 05:33 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
This is a very good post, and exactly the type of thing early hemi guys go through all the time.... fixin' up old heads.
TR Waters
Re: fixin' up old heads [Re: TrWaters] #929188
02/15/11 06:04 PM
02/15/11 06:04 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Just goes to show you that with a lot of money and hard work, those old doorstops can be brought back to life! Dwayne posts here about once or twice a year, but you can always count on him for a home run. Usually with well detailed pictures and great step by step facts. Da man!
2 kids and a dog
Re: fixin' up old heads [Re: TonyS451] #929189
02/15/11 06:15 PM
02/15/11 06:15 PM
Az
Crizila Offline
Crizila  Offline
Az
Quality work is easy to spot - chamfered bolt holes on resurfaced heads. Minor port work is done right where the pay-offs are biggest. Thanks for the post.
Fastest 300
Re: fixin' up old heads [Re: Crizila] #929190
02/15/11 07:49 PM
02/15/11 07:49 PM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
Great to see you back on here Dwayne, I have missed your posts!
Seeing this really makes me wonder why I am bothering with the factory heads I have. The deal I had done to get them machined for free fell through, so I may as well put my money into NEW heads that will last longer!
You have mail to Dwayne!
Alan Jones
Re: fixin' up old heads [Re: LA360] #929191
02/15/11 08:05 PM
02/15/11 08:05 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Thanks Dwayne. Your posts hve been missed!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: fixin' up old heads [Re: topfueldart] #929192
02/15/11 09:36 PM
02/15/11 09:36 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Thanks Dwayne! This is juust what I needed to finally convince me that the X heads on my 340 need to find a new home.
Re: fixin' up old heads [Re: slantzilla] #929193
02/15/11 09:51 PM
02/15/11 09:51 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Thanks, Dwayne. Nice read.
Re: fixin' up old heads [Re: Dean_Kuzluzski] #929194
02/15/11 09:55 PM
02/15/11 09:55 PM
LA360 Online boogie
LA360  Online Boogie
The 360 heads I have required or still require:
hot tanking
sand blasting
A full set of guide inserts
exhaust seat inserts
Machine for teflon guide seals
enlarge the spring seats
hone the guides
cut the seats
Machine out/extract broken exhaust manifold studs
re-machine worn corroded exhaust gasket face
Re-surface head
add in the cost of the core
What does it equal to? I probably could have a RHS head machined up for the same $$$ or less, even if it's a little more, I end up with a better cylinder head!
Alan Jones
Re: fixin' up old heads [Re: LA360] #929195
02/15/11 10:42 PM
02/15/11 10:42 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
There was a Dwayne guy that used to post on here LONG ago. Wonder if it's the same dude? Kinda miss him too...
