how do you fit an alternator in BB Abody w/plate
#928966
02/14/11 08:35 PM
02/14/11 08:35 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my Denso looks like a very tight fit. can i see what others are doing with their Alt setup in a Abody with a BB and a motor plate
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: how do you fit an alternator in BB Abody w/plate
[Re: sixpackgut]
#928967
02/14/11 08:40 PM
02/14/11 08:40 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I hung mine on the lower right side.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: tboomer]
#928970
02/14/11 09:26 PM
02/14/11 09:26 PM
sixpackgut
Charleston
ok, i just found mini one wire chevy style denso alt for $74. it says it is a 50 amp, is that enough for a street car?
i have used the bigger denso's from intrepds and rams and they always worked great but i have no idea how many amp they are
[Re: sixpackgut]
#928974
02/15/11 11:45 AM
02/15/11 11:45 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Ray, you need atleast a 100 amp alternator for a street car w/ a lot of electric crap on it. My 100 amp is barely enough for my car, but my electric fan does draw a lot of juice.
I use the DMI low mount kit on mine by the way. Fits pretty good w/ the motorplate.
[Re: an8sec70cuda]
#928975
02/15/11 03:49 PM
02/15/11 03:49 PM
sixpackgut
Charleston
what alternator? the big denso is no problem on my challenger but on the A body it is a problem. notice in this pic i have the engine plate sitting on 1" pieces of wood to give it enough room. but they are not staying there, i just had to do that while i was dropping it in. i even cut some of the plate to give it more room.
[Re: sixpackgut]
#928976
02/15/11 06:06 PM
02/15/11 06:06 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Here's mine with an andy F plate and the Summit alternator durring mock up
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: sixpackgut]
#928977
02/15/11 06:13 PM
02/15/11 06:13 PM
an8sec70cuda
Mine is the 100 amp Powermaster GM 1 wire that came in the kit that GregZ sold w/ the DMI bracket. One more reason I don't like motorplates w/ holes in them. I had to trim the bottom of mine to clear the alternator, but w/ the way mine is mounted, I have plenty of room. I have the big Comp Engineering solid plate. You have that cuda lookin good Ray!
[Re: an8sec70cuda]
#928978
02/15/11 09:30 PM
02/15/11 09:30 PM
sixpackgut
Charleston
Thanks Chip. hey, dont knock my motor plate, i bought it used off a member named HATE. Hey Andy F, is that a denso mini in the setup you posted? how many amp alt is that? anyway, the denso is to big to fit. i tried again tonight. how big is a GM alt? i only have have at most 7" of room. please excuse the orange overspray on my very expansive chrome balancer
[Re: sixpackgut]
#928979
02/15/11 09:36 PM
02/15/11 09:36 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I used a BBC bracket on my Duster....reversed on the righthand side..They are about $40.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: sixpackgut]
#928981
02/15/11 09:46 PM
02/15/11 09:46 PM
sixpackgut
Charleston
this is how i had it in the challenger forever. this wont work on a A body. Andy, how much money do i get every time i post a pic with your plate?
[Re: sixpackgut]
#928984
02/15/11 10:45 PM
02/15/11 10:45 PM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
This might help... Parts from Mancini Racing: Billet DMI Alt. bracket # BMAB040-R (88.95$) Billet DMI Alt. pulley # BMCT050-R (69.95$) Parts from Summit Racing: Powermaster 100Amp Alt. # PWM-8062 (239.95$) Pulley to Alt. # PWM-181 (26.95$) I had to modify one of the Alternator mounting brackets to line up the pulleys. I also had to make a small notch in the engine plate. http://forum.musclecars.nu/attachment.ph...mp;d=1296842515/Tom
