727 Alto Red Eagle Clutches #928360
02/13/11 11:47 PM
02/13/11 11:47 PM
Orangeville, Ontario, Canada
Red Express Offline OP
Rebuilding the 727 in the truck and wanted to get some opinions on these Red Eagle clutches.
Do you guys use them, would your use anything else.
Any other things I should look into when rebuilding to get the most out of this trans.
Has an ATI stall and reverse valve body... been in the truck along time. I've been told during previous rebuilds that the clutches and bands look good.
This past season my 60's have really fallen off so I'm thinking things may be slipping... Have not observed tire spin...
Darcy & Allan MacCoubrey Worlds Fastest Lil Red Express Truck 10.48 @ 128 mph [url] www.raceosca.com [/url].
Re: 727 Alto Red Eagle Clutches [Re: Red Express] #928361
02/14/11 06:30 AM
02/14/11 06:30 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
It's strange 1'st would go
I put a lot of power thru mine and 3'rd was always the problem.
Give Dwight a call. He can set you up with any info or parts you need.
Tell him Mark sent you.
http://www.profilecanada.com/companydeta...ampbellcroft_ON
Re: 727 Alto Red Eagle Clutches [Re: Red Express] #928362
02/14/11 06:52 AM
02/14/11 06:52 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
the alto red eagle clutches are what most people are using in their race/hp transmissions.
this is one of the best deals I have found:
http://cgi.ebay.com/ebaymotors/TF8-727-C...b#ht_1641wt_939
Re: 727 Alto Red Eagle Clutches [Re: 451Mopar] #928363
02/14/11 08:41 AM
02/14/11 08:41 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We have used Alto Reds in the past with good luck. Last years 727 we used Raybestos Stage 1 clutches and they worked great also.
Re: 727 Alto Red Eagle Clutches [Re: cl440] #928364
02/14/11 12:12 PM
02/14/11 12:12 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I found some mixed results depending on application. I found that if they are smooth, they have a tendancy to skid. I have not seen and Alto Reds for mopar direct clutch application that are grooved. But then again, may not be up on the latest available stuff.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
