440 Flywheel #928181
02/13/11 10:12 PM
02/13/11 10:12 PM
Pa
mopglen Offline OP
mopglen  Offline OP
Pa
I am trying to determine if the proper flywheel for a 71 challenger 440-6 should be 10.5 or 11" ? Any help to clear this up is appreciated.
Glen
Re: 440 Flywheel [Re: mopglen] #928182
02/13/11 10:51 PM
02/13/11 10:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Have you purchased a bellhousing yet?
That will determine what flywheel you need.
Gus
64 Plymouth Savoy
Dana 60
Re: 440 Flywheel [Re: fourgearsavoy] #928183
02/13/11 11:20 PM
02/13/11 11:20 PM
Pa
mopglen Offline OP
mopglen  Offline OP
Pa
Thanks. I was trying to determine what was origionally on the car. I believe the flywheel is supposed to be 10.5" from the factory?
Re: 440 Flywheel [Re: mopglen] #928184
02/13/11 11:45 PM
02/13/11 11:45 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
130 tooth flywheel - 10.95 clutch (same bolt pattern as 10.5 clutch).
Re: 440 Flywheel [Re: GomangoCuda] #928185
02/14/11 12:52 AM
02/14/11 12:52 AM
Pa
mopglen Offline OP
mopglen  Offline OP
Pa
Thanks for the info.
Re: 440 Flywheel [Re: fourgearsavoy] #928186
02/14/11 12:53 AM
02/14/11 12:53 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm pretty sure 143-tooth 11" flywheels were retired after '69.
