Page 2 of 3 1 2 3
Re: Help picking a cam [Re: Von] #927479
02/14/11 12:36 AM
02/14/11 12:36 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Please define better....and why more lift is needed with stock castings?
Ive already discussed the same subject with Dwayne...
True, it will run real nice with a stock cam.
Re: Help picking a cam [Re: RemCharger] #927480
02/14/11 12:38 AM
02/14/11 12:38 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
with a stock cam.
Ya, how do stockers run so well with sub 500 lift.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Help picking a cam [Re: Von] #927481
02/14/11 12:38 AM
02/14/11 12:38 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Relax man! Just adding to the choices out there for cams. We all know that MP cams were not mentioned in the post. So, no harm done to the Comp Cams followers. Respectfully, they (CC's) are a good design also.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Help picking a cam [Re: HYPER8oSoNic] #927482
02/14/11 12:41 AM
02/14/11 12:41 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Relax man!
Re: Help picking a cam [Re: Von] #927483
02/14/11 12:52 AM
02/14/11 12:52 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
with a stock cam.
Sorry, I didn't realize the OP is building a Stock/SuperStock car.
Must be reading to fast.
Re: Help picking a cam [Re: Von] #927484
02/14/11 01:12 AM
02/14/11 01:12 AM
Desert Tracker
Desert Tracker
In SOME instance more lift to a point in relation to duration, equates to MORE TORQUE. Mopar BB heads flow pretty good for street/MILD strip usage
w/o "heavy" massaging. A MODERATE duration/higher lift cam is best for a hot streeter. Bigger (longer duration) cams want bigger port/valve heads. Not needed here!! The K.I.S.S. principle.
Re: Help picking a cam [Re: RemCharger] #927485
02/14/11 01:12 AM
02/14/11 01:12 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
with a stock cam.
You got me ROTFLMAO...
http://www.moparts.org/Tech/Archive/bb/Lobe.html
Dang RB and MP old technology....Sure wish they would have tested some of the newer shiznit grinds. Oh wait...they did...
Peace Out!!!
Re: Help picking a cam [Re: 71TA] #927486
02/14/11 01:18 AM
02/14/11 01:18 AM
Desert Tracker
Desert Tracker
I went with an old skool MP528 mechanical. WOW what a great cam. Daily driveable, medium lope, fries the 295/60-15 BFG drag radials thru 3.55 gears. 470". See info in my profile.
Good setup!!
Re: Help picking a cam [Re: Von] #927487
02/14/11 01:31 AM
02/14/11 01:31 AM
Desert Tracker
Desert Tracker
Here, I'm throwing it back at ya!!
The update (test page), works WELL for 3500-3600 pound B-bodies. The poster
has nearly TWO-TONS of car. The performance of those cams DO NOT relate to his CAR WEIGHT!! Look, I'm not knocking the newer cams, but you fail to realize that WEIGHT effects the perfomance. You can make horsepower, but torque is needed to move the MASS effectively. Want to run HARDER, lighten the car!! THEN, pack in the horsepower. BTW, the RACER BROWN cam
looked pretty good, probably the most driveable one of the bunch!
Re: Help picking a cam [Re: HYPER8oSoNic] #927488
02/14/11 01:44 AM
02/14/11 01:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Well his combo is almost identical to mine. I run a .030 over 440 with stock bottom end other then the KB quench pad pistons that give me quench with my open chamber 906 heads. Its 10.0 comp and I run the Holley Street Dominator intake with an 850 DP. I have Hedman 1-3/4 headers and use a Dynamic 9.5 converter that flashes about 4200 at the track. My 63 weighs just over 3700 with me in it and I use 4.30's with a 30 x 9 tire. I use the MP .557 cam and I have ductile iron 1.5 rockers. Suspension is all stock other then SS springs and 90/10 shocks up front. Best et is 11.49 @ 116 with 11.50's to 11.70's the norm is hot weather. I drive on the street way more then I race it as I only race 2 or 3 times a year but put alot of street miles on it. I like the .557 cam as it makes ok power and has great driveability on the street. Ron
Re: Help picking a cam [Re: 383man] #927489
02/14/11 01:54 AM
02/14/11 01:54 AM
Desert Tracker
Desert Tracker
Thanks Ron. Great input.
Keep Maxin' em', my friend!!
Re: Help picking a cam [Re: HYPER8oSoNic] #927490
02/14/11 01:56 AM
02/14/11 01:56 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
How do the cams NOT relate to car weight??? Look at the torque #s the RB cam put up.
I think you are not seeing my problem with some of the comments on this thread,and most other cam threads. To make the statement that "this cam, or that cam sucks, is out dated, is a SHi445 pos, etc", is totally ridicoulous.
As you said its all in the combination......I agree that most cam related problems are due to other issues, (compression, converter, advance curve, tuning, etc)
But, as in forphorty's case (whose car is no lighweight, 3600 and change I believe) if I asked 100 people what his car runs with no compression, 3.23s, very little headwork, and a high mileage motor to boot, most generally the answer would be "That cam is too big, it will be a flippin hound" or something along those lines.
Too many blanket statements thrown out on this board that are at best half true.
Re: Help picking a cam [Re: Von] #927491
02/14/11 01:57 AM
02/14/11 01:57 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
with a stock cam.
Peace Out!!!
Could you at least post the whole article? I didn't see the part about the sub 500 lift cams.
Andy is a serious asset to the mopar community, I'm honoured to see he recommends the same hydraulic as I do
Glad we can finally agree and move forward.
Re: Help picking a cam [Re: RemCharger] #927492
02/14/11 02:05 AM
02/14/11 02:05 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
You hittin a crack pipe? Where did I say they tested sub 500 lift cams....
Not so fast there, pundit. Looks like the old school crap RB cam took the honors.... Something to the lines that they could tell the shiznit Comp hyd didnt have the low end that the RB cam had and the dyno backed it up. Hmm, split duration had less torque than the POS old school RB, where have I heard that before?
Re: Help picking a cam [Re: Von] #927493
02/14/11 02:25 AM
02/14/11 02:25 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
BTW, which cam company is high lighted in the sources box??
I'm not going to dwell into Andys article as he would tell you ,which I'm sure you know, every combination is different.
I said I like the XE284 over the old comp 292/501. You got agitated. Too bad we couldn't have a dyno shootout in that motor and see.Probably wouldn't end up being that far from each other.
Re: Help picking a cam [Re: RemCharger] #927494
02/14/11 02:28 AM
02/14/11 02:28 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[quoteI said I like the XE284 over the old comp 292/501. You got agitated.
Actually said that the 292 was a shi%%^ old cam. But,no harm no foul.
Now back on track, so to speak...
Re: Help picking a cam [Re: Von] #927495
02/14/11 02:33 AM
02/14/11 02:33 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Re: Help picking a cam [Re: RemCharger] #927496
02/14/11 02:46 AM
02/14/11 02:46 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I reread the post and yea it sounded like I was cutting your car down fourforty, that was not my intention, I apologize. Just spiralled from there ,sorry guys.
Re: Help picking a cam [Re: RemCharger] #927497
02/15/11 09:09 AM
02/15/11 09:09 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Thats MY 470" shortblock in that article. I bought it off AndyF (Moparts member that DID the article). Actaully when I got it it HAD a CC cam in it. I pulled it and returned it (he dynos with Schubecks) and put in an MP528. Installed and broke it in one evening while also cooking dinner for the familiy after work. Just spagetti.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Help picking a cam [Re: Verga] #927498
02/15/11 02:13 PM
02/15/11 02:13 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
10:1, 2" headers, 4000 stall and 4.10s.
Yep, put a .557 MP cam in it and let it eat.
Rich H.
Esse Quam Videri
Page 2 of 3 1 2 3
