Roller rockers and stock 69 valve covers #926139
02/11/11 11:29 AM
02/11/11 11:29 AM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Doing a BB 400 stroker, I want to use a hydraulic roller cam, and adjustable rockers. What will fit under 69 style valve covers?
Thanks,Dave
Re: Roller rockers and stock 69 valve covers [Re: 4404dart] #926140
02/11/11 11:40 AM
02/11/11 11:40 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not w/o beating the baffles up.
Coming soon!!!!
Re: Roller rockers and stock 69 valve covers [Re: Mr.Yuck] #926141
02/11/11 11:50 AM
02/11/11 11:50 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
X2,...I used factory 70 BB valve covers on my build using Crane's roller rockers, and had to loose the baffles completely for clearance,...no biggy, no problems with anything else, or no running problems/leaks/etc
Re: Roller rockers and stock 69 valve covers [Re: DAYCLONA] #926142
02/11/11 04:40 PM
02/11/11 04:40 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Thanks, that's what I figured, just wondering if one kind ( stainless,aluminum) or another might clear.
Re: Roller rockers and stock 69 valve covers [Re: 4404dart] #926143
02/11/11 06:53 PM
02/11/11 06:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I went w/ Morosos. They are baffled and work fine w/ 1.5 rollers
Coming soon!!!!
Re: Roller rockers and stock 69 valve covers [Re: Mr.Yuck] #926144
02/11/11 11:50 PM
02/11/11 11:50 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Comp Cams Pro Magnum roller rockers are pretty low profile especially compared to aluminum rockers. I run them on my SB stroker with .590" lift no problems hitting the stock valve cover baffle.
Re: Roller rockers and stock 69 valve covers [Re: Mr.Yuck] #926145
02/11/11 11:51 PM
02/11/11 11:51 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
If the rocker shaft mounts are square on top, you'll have to chamfer the end corners to avoid dimpling the covers. I have 1.6 Harland Sharps & Eddy heads on my 440, and by denting the baffles for clearance and chamfering the rocker stands, the OEM '69 covers fit fine using thick cork gaskets.
Re: Roller rockers and stock 69 valve covers [Re: topside] #926146
02/12/11 01:24 AM
02/12/11 01:24 AM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Thanks everyone, some good info, at least I have some options.
