Small Block Rear Main Seal Question
#926078
02/11/11 02:47 AM
02/11/11 02:47 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I am assembling a 408 stroker from parts I gathered back in 2001. I am using a new unopened FelPro gasket set. The rear main seal was in a separate sealed plastic bag and came with a little blue shoe horn that you are supposed to use to coax it into place. Well these dropped right with little resistance. They look good but are significantly stiffer in composition than the oil pan gaskets in the same kit. I have the crank and caps in place but am wondering if I should use this new but 9 year old seal. I see Felpro lists 2 seals for the 360 one is made with Viton and more expensive QBS40651 and QBS40251 which is silicon I think, I think I know the answer . . . .. . buy an new one and dont take chances. Just wondering if there is a preferred brand or part number.
Thanks Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
Re: Small Block Rear Main Seal Question
[Re: Mopar73340]
#926080
02/11/11 12:07 PM
02/11/11 12:07 PM
finadk
East Brunswick, NJ
Thanks, Sorry you had such troubles. I laid the crank in last night and was aboutto torque it all down and I started thinking "what if". Im glad I asked. Thanks for the insight and the info. Scott
Scott
1976 Corvette
[Re: finadk]
#926081
02/14/11 11:12 AM
02/14/11 11:12 AM
finadk
East Brunswick, NJ
Just an update to the board in case anyone is looking for a rear main seal for a 360. The Felpro part number for the orange / brownish Viton rear main seal with two sealing lips for the LA 360 is BS40651 it's about $25.
The standard one that comes in the gasket set is rubber And the part number is BS40094 and is a single lip design. It's about $16.
Scott
Scott
1976 Corvette
