Page 4 of 5 1 2 3 4 5
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: MattW] #921829
02/26/11 10:15 PM
02/26/11 10:15 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Matt, someone just posted on the LX forums that the first digit is the year so i guess your right. and if your right then i cant believe that so many people couldnt answer that.
the same part number on the heads really threw me for a loop
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: MattW] #921830
02/28/11 09:39 AM
02/28/11 09:39 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
does someone else make a flex plate for smaller vert with the larger 7/16ths bolt holes
MP sells it. P5153753.
Early and late 5.7s are real easy to tell apart by looking at the front cam bearing hole. If it's giant sized and there's an extra oil passage that goes up to where the control solonoid is, it's a late one. If it looks fairly normal and only has a pressure hole, it's an early one.
Rich H.
Esse Quam Videri
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: ZIPPY] #921831
02/28/11 01:26 PM
02/28/11 01:26 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
hey, its on sale at jegs
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: nhramark] #921832
02/28/11 04:23 PM
02/28/11 04:23 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
also whats the motor mount situation.?
cheapst
Can't help with the motor mount, but we do make a nice motorplate. This one has the optional alternator kit on it.
VERRRRY interesting. What application is the water pump, or are they made for a G3 Hemi now??
Can you do a plate with the alt mount kit on the passenger side??
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cudadoug] #921833
02/28/11 08:09 PM
02/28/11 08:09 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Shouldn't be a problem to switch the alt mount. Not sure if they have a Gen 3 unit now, but we have a part number that works with our plate.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sixpackgut] #921834
02/28/11 10:16 PM
02/28/11 10:16 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
All the new Hemis oil the lifters from the push rod/ rocker shafts. Its backwards to what we are used to. This was done to accommodate the MDS system. Quoted from the FSM:
Engine oil stored in the oil pan (5) is drawn in and discharged by a gear rotor type oil pump (2, 3). The oil pump is directly coupled to the crankshaft (1). Oil pressure is regulated by a relief valve (4). The oil is fed through an oil filter and to the crankshaft journals from the oil gallery (8) in the cylinder block. This gallery also feeds oil under pressure to the cylinder heads. Oil flows through each cylinder heads oil passage to the rocker shafts (10, 16). Oil then feeds the camshaft journals (12), rocker arms, and hydraulic lash adjusters.
OIL FLOWS TO ONLY ONE PEDESTAL ON EACH HEAD - SECOND FROM REAR ON RIGHT HEAD - SECOND FROM FRONT ON LEFT HEAD
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: Dave_S] #921835
02/28/11 10:39 PM
02/28/11 10:39 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
far out
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sixpackgut] #921836
03/01/11 08:41 AM
03/01/11 08:41 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
A friend of mine manufactures a few 3rd gen hemi parts.
http://www.thecrankshopvt.com/index.php?cPath=22&osCsid=f18b206e7b0c8f37377bcb7fc8e74cc6
He was the first with the intakes and valve covers.
TR Waters
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: STEFF] #921837
03/27/11 12:18 AM
03/27/11 12:18 AM
San Angelo, Texas
Cevidicus Offline
Cevidicus  Offline
San Angelo, Texas
Iv'e had an '09 5.7 Hemi Eagle for over a year now. I have called around, researched, discussed, daydreamed till my head was ready to explode. Stu and the boy's at Inertia Motorsports have been quite helpfull.
Basically, you have 4 options if you have an '09+ 5.7 and want to run it in a classic body.
1. FACTORY EFI/IGNITION:(has been done in Jeeps by BG) Use a 2009+ 5.7 Challenger 6-speed pcm, intake, throttle body, injectors, electronic throttle pedal, HotWire harness,(+ anything I left out) and a custom tune on the pcm. Including the tune this is right around $3,000 and will make use of the VCT function. If you have MDS, you will have to replace the MDS lifers and yokes. Which requires removing the heads so new head gaskets and head bolts would be a good idea, but may not be needed.
2.CARB THE '09: Weld cam phaser to cam gear. Some trial and error with the degree wheel needed to get the cam positioned right. Might as well get a reground cam while you're at it. Camselection is quite limited. One could also get a custom ground billet cam if $800 is not an issue. So, weld phaser & degree cam, reground cam, push rods, non-mds lifters/yokes, head gaskets, and labor is about $900. Plus you will have to run the FAST XMI ignition ($700-775 with harness) because the MSD will not work with the '09's tone wheel. Also add carb compatable 6.1 style intake manifold.
3. AFTERMARKET EFI WITH VCT FUNCTION: Electromotive XDI Nobody has done it and it is like 4500 just for the electronics and the plugs/wiring which you have to adapt to your application. Plus dyno tuning time, intake, throttlebody, injectors and so on.
4. BLOCK SWAP: Swap the internals from the '09+ into an '08 down block. Factory 08 down efi may not work due to the 52 tooth tone wheel on the 09 crank. 08 down uses a 32 tooth wheel, I believe.
There are pro's and con's to each approach. None really qualify as cheap. All require a well thought out plan.
If one wants a more agressive/radical engine in the stock displacement, a block swap makes the most sense. This is due to the availability of cams for the 08 down blocks.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sixpackgut] #921838
03/27/11 12:48 AM
03/27/11 12:48 AM
houston texas
gremlinsteve Offline
houston texas
heads are also oiled via the rocker "towers".
they get preassure via a passage in the block.
steve
a couple things
1st, i was looking at the flexplate conversion on mancinis website and it appears to me that it will only accept a larger style converter with the small 5/16ths converter bolts. does someone else make a flex plate for smaller vert with the larger 7/16ths bolt holes
the next thing is, i was trying to study the rocker gear oiling system today. to me it looks like oil thru the pushrod and that oil then fills the rocker shaft to push oil out the other side of the rocker to oil the springs which then got me thinking about how will the harland sharpe rockers work with needle bearings and even more so with an adjustable rocker arm. i would want to look at the rockers and how their designed before i bought them. unless of course you were to run oil lines to the shafts
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: gremlinsteve] #921839
03/27/11 12:56 AM
03/27/11 12:56 AM
houston texas
houston texas
09 motors have no cam cores available from the core companies that i know of. most if not all cams i know of the the vvt motor is reground stock cores.
the 09 motor uses a differant timing cover from the older design also.
the intake is differant also. as are the heads.
i like the idea of losing that cam phazer, but cam choice is not there yet. its almost worth selling that 09 short block and picking up a decent 08 and older one. heck, i have several im fixing to toss because there in my way...lol
there are aftermarket crank kits available for the vvt 5.7 cars/motors making them 390-396 inchers...but limited cam choices for that route also..
steve
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: gremlinsteve] #921840
03/27/11 01:15 AM
03/27/11 01:15 AM
San Angelo, Texas
Cevidicus Offline
Cevidicus  Offline
San Angelo, Texas
steve
I beleive Crower has the billet cam cores.
The regrinds are limited on intake centerline and duration.
I would like to see someone make a non VVT timing set and cam. It'll be a while if ever. Also an aftermarket ECU that works on the VCT like the MAST unit for the LS motors would be nice.
Will the 09 timing cover fit an earlier block?
You can toss those blocks you have in the way up here...
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: Cevidicus] #921841
03/28/11 09:06 AM
03/28/11 09:06 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
Now this is getting good.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921842
03/28/11 09:17 AM
03/28/11 09:17 AM
houston texas
houston texas
ill check my i as of last week was still not able to get cores for them vvt motors. i might try crower for a blank.
the 5.7 eagle piston is differant also. since the eagle head has only got about a 66cc head chamber. the old 5.7 came in about 87
steve
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: STEFF] #921843
03/28/11 09:19 AM
03/28/11 09:19 AM
houston texas
houston texas
i have a clut away of a 09 head if you wanna see what they look like cut in half. i think the file is too big to post here so ill have to email it to some one.
steve
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: Cevidicus] #921844
03/28/11 01:38 PM
03/28/11 01:38 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That's a nice summary sweeth2o, well written.
For now, VVT/VCT is a pain to modify and really not very user friendly.
Rich H.
Esse Quam Videri
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sam64] #921845
03/28/11 04:07 PM
03/28/11 04:07 PM
houston texas
houston texas
who can i send these pics to so yall can post em. there too big for the sight.
steve
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: ZIPPY] #921846
04/09/11 02:37 AM
04/09/11 02:37 AM
San Angelo, Texas
Cevidicus Offline
Cevidicus  Offline
San Angelo, Texas
Thanks!
Im hoping that since the new SRT 392's have vct that something may come up. Surely Mopar will put out a crate engine based on the new VCT engines at some point sooner or later.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: gremlinsteve] #921847
04/09/11 10:40 AM
04/09/11 10:40 AM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
steve
Send it to me, I can resize and post it. n2mopars@gmail.com
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: Cevidicus] #921848
04/09/11 02:09 PM
04/09/11 02:09 PM
San Angelo, Texas
Cevidicus Offline
Cevidicus  Offline
San Angelo, Texas
Pics From Gremlin Steve
