Page 3 of 5 1 2 3 4 5
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: STEFF] #921809
02/11/11 09:36 PM
02/11/11 09:36 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
so which oil pan is needed to fit the motor in a muscle car..A body for that matter.
or do you have to hack the k member.
the car pan i have is a front sump.
also whats the motor mount situation.?
cheapst
The Milodon pan fits nice!! if you put the motor in stock location. I moved mine as far back to the firewall, so I had to add a clearance pocket for the drag link.
I used a motor plate for mounting motor & I built my own headers, since I moved the motor around & put it as low as possible in the engine bay.
What type of rocker system are you using?
I wonder why BES went with the jesel setup in their EMC.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: MattW] #921810
02/11/11 09:53 PM
02/11/11 09:53 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
I'm using the stock rockers. I've talked to enuff people & asked enuff questions about them. They're plenty strong for a street/strip deal.
As for the Jesel stuff, if you can swing it, why not use it? It's top shelf.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: 6PKRTSE] #921811
02/11/11 09:54 PM
02/11/11 09:54 PM
SC304 Offline
SC304  Offline
We just did a 6.1L super stock legal engine for a customer of ours & almost made 700 HP N/A. 689/586 to be exact. Not bad.
is that going to be in SS/E??
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: STEFF] #921812
02/12/11 11:08 AM
02/12/11 11:08 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Yeah but at 3200.00 how much of a gain do you get with a hydraulic cam?
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: MattW] #921813
02/12/11 11:13 AM
02/12/11 11:13 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: SRT6776] #921814
02/12/11 01:37 PM
02/12/11 01:37 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: MattW] #921815
02/13/11 02:52 AM
02/13/11 02:52 AM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
Harland Sharp will have some adjustable roller rockers out soon for around $1800.Still not cheap, but at least it's another choice if you want to run a solid lifter roller cam.
http://www.harlandsharp.com/hemi.htm
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: Ray440] #921816
02/13/11 10:57 AM
02/13/11 10:57 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Yeah I know about the Harland Sharp rockets and there is another one by HHP. I think theirs is non adjustable.
At 3200 or 1800 a set I rather sink my $$$ into a rotating assembly.
I know in an all out motor trying to get every last ounce of hp you could justify it but how much is there to gain using roller adjustables in a hydraulic
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: MattW] #921817
02/14/11 12:22 PM
02/14/11 12:22 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Maybe soon a hydraulic won't be mandatory, and they're anticipating the need
Header wise, I've seen + 50 ft lbs at only 2000 rpm with a long tube 1&7/8 primary, into a 2&3/4 collector, on an otherwise stock 5.7
Rich H.
Esse Quam Videri
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: ZIPPY] #921818
02/14/11 05:03 PM
02/14/11 05:03 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I heard those logs were restrictive. When do you think RAS will come out with a rocker arm system? Matt Sent U a PM
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: STEFF] #921819
02/24/11 08:56 PM
02/24/11 08:56 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Steff, not asking you, in particular but, anybody that knows......
What would/do you run for transmission and converter with the new HEMI?
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: S/ST 3040] #921820
02/24/11 09:13 PM
02/24/11 09:13 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Same bolt patern as the LA smallblock.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: MattW] #921821
02/24/11 09:28 PM
02/24/11 09:28 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
where do they put a date on the engines? i have a hemi sitting in my garage and dont know what year it is
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sixpackgut] #921822
02/24/11 09:49 PM
02/24/11 09:49 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
so $490 for a set of eagle heads and $1800 for rocker arms..
that dollar cost averages to $2290 for a set of 700hp heads...
whats the dilema?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: S/ST 3040] #921823
02/24/11 10:09 PM
02/24/11 10:09 PM
STEFF Offline
STEFF  Offline
I'm using a Turbo 400 with a JW Ultrabell.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: STEFF] #921824
02/26/11 08:15 PM
02/26/11 08:15 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
a couple things
1st, i was looking at the flexplate conversion on mancinis website and it appears to me that it will only accept a larger style converter with the small 5/16ths converter bolts. does someone else make a flex plate for smaller vert with the larger 7/16ths bolt holes
the next thing is, i was trying to study the rocker gear oiling system today. to me it looks like oil thru the pushrod and that oil then fills the rocker shaft to push oil out the other side of the rocker to oil the springs which then got me thinking about how will the harland sharpe rockers work with needle bearings and even more so with an adjustable rocker arm. i would want to look at the rockers and how their designed before i bought them. unless of course you were to run oil lines to the shafts
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sixpackgut] #921825
02/26/11 09:14 PM
02/26/11 09:14 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
a couple things
If you look at the heads What are the two holes in the rocker stands.both sides 2nd stand in from end. Is that oiling through the rocker shaft like the LA engine.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: MattW] #921826
02/26/11 09:42 PM
02/26/11 09:42 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
a couple things
i didnt notice that. i'm going to look
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sixpackgut] #921827
02/26/11 09:52 PM
02/26/11 09:52 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
a couple things
the holes are drilled to a head bolt hole. i dont have the heads off the engine but i think it must an oil feed to the shafts
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sixpackgut] #921828
02/26/11 09:57 PM
02/26/11 09:57 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
a couple things
Thats what I was thinking, and they are at both ends. You got to love the new stuff
