Page 1 of 5 1 2 3 4 5
3rd gen HEMI swap for drag racing...tricks for power. #921769
02/05/11 09:33 PM
02/05/11 09:33 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
i just aquired a low mile 09 hemi replacement long block complete engine..
where is a good place to learn about tricks for the new hemi's
i thinking of stroked with a power adder for the drag only duster...
rignt now its a complete running motor.
i dont know if i should keep the efi or go something else..?
who knows what and where to learn up..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921770
02/05/11 09:47 PM
02/05/11 09:47 PM
K
Kiddart Offline
Kiddart  Offline
K
there are alot of guys here in the detroit area putting on a procharger and blowing your socks off right out of the box call the procharger store they will hook you up good not sure if it will be on hte cheap but it will be effective, I am looking for a motor and tranz for my dart as well.
Thank you
Kiddart
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: Kiddart] #921771
02/05/11 10:00 PM
02/05/11 10:00 PM
can i run a 727 with it or do i need the hemi transmission? i have it...but had planned on using the 727?
cheapst
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921772
02/05/11 10:07 PM
02/05/11 10:07 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
3rd Gen Hemi's have the small block bell housing bolt pattern. Mopar makes a flex plate for mating to the converter.
Check out www.lxforums.com. There are a ton of vendors that support the site & offer parts for 3rd Gen Hemi's.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: STEFF] #921773
02/05/11 10:15 PM
02/05/11 10:15 PM
thanks ill take a look...
cheapst.
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: STEFF] #921774
02/05/11 10:17 PM
02/05/11 10:17 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
i am interested as well. With the heads capable of big cfm compared to an average small block head, they seem to be an interesting alternative to run of mill engine builds. i think they are an alternative.
i think a drag pak intake may be beneficial, but could be costly.
if it is an 09 engine, you have one piece to the puzzle, which are the eagle casting heads, that flow well for OEM castings.
justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921775
02/05/11 10:18 PM
02/05/11 10:18 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We just did a 6.1L super stock legal engine for a customer of ours & almost made 700 HP N/A. 689/586 to be exact. Not bad.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921776
02/05/11 10:47 PM
02/05/11 10:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I don't think there are any cams out yet for the 09 hemi as it uses a very different drive set up for the variable cam timing. The heads are almost as good as it gets. I have heard of 440 inch gen III hemis and people are running them at 700 hp on routine basis and I have not heard of a block failure yet on either the 6.1 or 5.7.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: wldtm] #921777
02/05/11 11:03 PM
02/05/11 11:03 PM
STEFF Offline
STEFF  Offline
About $1000, if you can find one.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: STEFF] #921778
02/05/11 11:06 PM
02/05/11 11:06 PM
i was thinking sheetmetal and 2-4's
but what ignition..?
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921779
02/05/11 11:19 PM
02/05/11 11:19 PM
STEFF Offline
STEFF  Offline
I've got the FAST stand alone ignition controller. MSD makes one as well. They both run using the factory coil packs, crank & cam sensors. MSD also has hotter coils, but I'm waiting on Rick Gorsky & Firecore. He said they'll be coming out with hotter coils as well.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921780
02/05/11 11:24 PM
02/05/11 11:24 PM
okla.
sam64 Offline
sam64  Offline
okla.
the msd hemi 6 uses the factory crank,cam,map sensers,and is tuneable on the advance curves.i have 2 on 2004 5.7 carbed street cars.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sam64] #921781
02/06/11 11:24 AM
02/06/11 11:24 AM
so do i need a differnt block short block?
or can i delete the vvt cam set up?
i want to stroke it..what cranks are available?
are these cyl bores able to be bored? or is the
finish on them too hard?
if so..how big from 3.90 can i go?
cheapst
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921782
02/06/11 12:08 PM
02/06/11 12:08 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
If I was going to build a late model HEMI (and I might) to race, I'd
get ahold of board member, gremlinsteve. It seems he was the
guy doing these for a while now.
I heard, at some point there was supposed to be an aluminum block
built for race purposes but, haven't seen/heard of anything recently.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: S/ST 3040] #921783
02/06/11 12:54 PM
02/06/11 12:54 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
http://www.hotrod.com/techarticles/113_0708_426_hemi/index.html Pistons will need to be changed for serious cyl. pressure.
Yeah, it's got a smallblock.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: S/ST 3040] #921784
02/06/11 01:51 PM
02/06/11 01:51 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Just before Christmas I received an email from Mopar news saying the aluminum blocks were great Christmas presents at almost $10,000, LOL http://www.bouchillonperformance.com/61LHemiAluminumBlocks.asp
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: S/ST 3040] #921785
02/06/11 03:01 PM
02/06/11 03:01 PM
STEFF Offline
STEFF  Offline
I talked to gremlinsteve....nice dude!! And, very knowledgeable.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: S/ST 3040] #921786
02/06/11 08:26 PM
02/06/11 08:26 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Aluminum block are out there but they are at 4600.00 Matt
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: MattW] #921787
02/06/11 08:52 PM
02/06/11 08:52 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
There is a guy who works for Arrington Engines - AJ is his name - he runs his street driven ( does not own a trailer) hard!
runs in the high 10's with a 6.1 based engine ( NA ) at 4400 lbs.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921788
02/07/11 02:39 PM
02/07/11 02:39 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
'08-down 5.7 has near unlimited aftermarket cam support.
'09-up 5.7 has basically no aftermarket cam support at all, unless you include the welded up, reground stock cams that are floating around out there....
It's not easy to delete the vvt from a 2009-up 5.7 shortblock because the front cam journal is huge, much bigger than the old style cam. The old style cam would fall right through the hole in the block....and as said the drive is different also.
It's much easier to get a 2008 or earlier 5.7, or a 6.1, and start with that instead.
Rich H.
Esse Quam Videri
