Page 2 of 5 1 2 3 4 5
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sam64] #921789
02/07/11 06:18 PM
02/07/11 06:18 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
the msd hemi 6 uses the factory crank,cam,map sensers,and is tuneable on the advance curves.i have 2 on 2004 5.7 carbed street cars.
I'm curious..... how do those cars run? ET? Weight?
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: S/ST 3040] #921790
02/10/11 02:20 PM
02/10/11 02:20 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
bump bump
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: ZIPPY] #921791
02/10/11 06:51 PM
02/10/11 06:51 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
'08-down 5.7 has near unlimited aftermarket cam support.
'09-up 5.7 has basically no aftermarket cam support at all, unless you include the welded up, reground stock cams that are floating around out there....
It's not easy to delete the vvt from a 2009-up 5.7 shortblock because the front cam journal is huge, much bigger than the old style cam. The old style cam would fall right through the hole in the block....and as said the drive is different also.
It's much easier to get a 2008 or earlier 5.7, or a 6.1, and start with that instead.
for those that know these motors..
if i have a 08 or older block (non VVT) will all of my internals from the 09 motor fit the block
sans a new cam and some valve train hardware?
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921792
02/10/11 06:56 PM
02/10/11 06:56 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
i just ordered a set of 09 eagle heads for an 04 short block.
cheapst .... i am not sure about your question.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921793
02/10/11 07:50 PM
02/10/11 07:50 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
cheapst
I THINK, not sure, that your statement is correct. The block is the same except for the cam. I hope so, IF NOT there will be an even bigger gap in the aftermarket. Matt
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: MattW] #921794
02/10/11 08:41 PM
02/10/11 08:41 PM
okla.
sam64 Offline
sam64  Offline
okla.
s/st 3040,mine are just street cars but in 65 dodge coronet,68 cuda fb,they seem to have very good low end torque.both are 2004 truck engines with the car oil pans and xv motorsports carbed kits.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sam64] #921795
02/10/11 09:34 PM
02/10/11 09:34 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Dirt track,,,,??
If you like drag racing, support your local track.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sam64] #921796
02/10/11 10:49 PM
02/10/11 10:49 PM
so which oil pan is needed to fit the motor in a muscle car..A body for that matter.
or do you have to hack the k member.
the car pan i have is a front sump.
also whats the motor mount situation.?
cheapst
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921797
02/11/11 12:36 AM
02/11/11 12:36 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
TTI makes mounts for an A-body
You can get a pan from Milodon, or I had a pan made by Weldtech out of canada (i think) for the same price the Milodon was originally priced at.
Headers are made by TTI for both 6.1 and 5.7, not necessarily the most sought after for performance, but they fit nice for long tubes.
Justin
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921798
02/11/11 10:31 AM
02/11/11 10:31 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
cheapst
The Milodon pan fits nice!! if you put the motor in stock location. I moved mine as far back to the firewall, so I had to add a clearance pocket for the drag link.
I used a motor plate for mounting motor & I built my own headers, since I moved the motor around & put it as low as possible in the engine bay.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: STEFF] #921799
02/11/11 10:54 AM
02/11/11 10:54 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
post some more specs about the car and the engine STEFF!
I am looking for a cast drag pack intake, but I am sure it is steep from the dealer, any idea on cost?
Looks very nice....
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: wldtm] #921800
02/11/11 11:14 AM
02/11/11 11:14 AM
STEFF Offline
STEFF  Offline
Looks very nice....
I've posted a bunch of pics in a few different posts of mine. You'll find them if you do a search thru my profile.
Drag Pack Intakes are about $1000. Thats what I paid thru Indy, as they were the only one that had one, when I was looking for one. I was going to get one thru Dave Hakim at Mancini for a little less money, but it seems Mopar doesn't keep them in stock, too well. Zippy can tell you if there are any in the system.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921801
02/11/11 01:55 PM
02/11/11 01:55 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
cheapst
Can't help with the motor mount, but we do make a nice motorplate. This one has the optional alternator kit on it.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: nhramark] #921802
02/11/11 02:00 PM
02/11/11 02:00 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
We also make these header flanges for those who want to build their own headers.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: nhramark] #921803
02/11/11 02:32 PM
02/11/11 02:32 PM
okla.
sam64 Offline
sam64  Offline
okla.
by car oil pans i should have said i have both a milidon,and a charlies oil pans on my rides.as for the mounts thet are very easy to fab because the bosses on the side of the block are flat.see nhramarks last pic to see the bosses.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: sam64] #921804
02/11/11 07:47 PM
02/11/11 07:47 PM
ok great so far..good info..
what is the consensus on header primary I/D and length..
do you step them at all or..?
Steff yours look nice..i couldnt tell if you had a factory steering box or rack? i see the factory drag link...so ...
how hard is it to fit in with factory steering column and factory box?
is the current magnum mini starter the same for these motors?
also anyone want to exapand on the XV ignition?
i suppose the cast intake is the only real choice..i was thinking 2-4's..fwiw.
cheapst
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: wldtm] #921805
02/11/11 07:54 PM
02/11/11 07:54 PM
well since i have a 09 engine complete..
i could buy a non vvt block and use the internals from the 09 but have the standard cam option..
ive got a line on a 04 5.7 block standard bore for 150 bucks?
for sure i want to put a real cam in it..
and would like to run it with stock bottom end first with maybe ported 09 heads..
id really like to do more cubes but it will have to be down the road.
so good cam and 4bbl run it as is..then learn about it..
and switch to a stroker..besides if the pistons are weak...instead of just pistons id stroke it.
i dont want to spend double money..so i was thinking keep the 09 motor..get it in the duster..
then build the stroker out of the 04 5.7 block
and swap the rest of the parts from the 09 onto that..?
just sort of looking for a plan of action..
cheapst
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921806
02/11/11 07:59 PM
02/11/11 07:59 PM
i havent turned a bolt on it yet...so i have no idea what it looks like inside of the 09
could i fab up some sort of spacer to fit a non vvt cam into it..?
or invest in the non vvt block?
cheapst
[image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921807
02/11/11 08:40 PM
02/11/11 08:40 PM
okla.
sam64 Offline
sam64  Offline
okla.
xv kits use the msd hemi6 system.
Re: 3rd gen HEMI swap for drag racing...tricks for power. [Re: cheapstreetdustr] #921808
02/11/11 08:49 PM
02/11/11 08:49 PM
STEFF Offline
STEFF  Offline
cheapst
I just went with straight 2" primaries to 3 1/2" collectors. I figured they may be a little big now for the stock cubes, but will be fine when motor is larger. I have the FAST stand alone ignition controller.....so far so good. MSD has one too. I went with FAST planning on going to F.I. in the future & will use the FAST XFI unit.
Factory steering Box & drag link etc.....it all fits fine. The #1 exhaust port was the only tube I had to work around the steering box, as I lowered & moved the motor back.
I'm using a Turbo 400 trans, so I have an Ultrabell & am using the standard run of the mill Mopar light weight starter.
I'm partial to the Drag Pack intake, but Indy's Mod manifold or Edelbrock's two-four manifold would be neat.
