3rd gen HEMI swap for drag racing...tricks for power.
#921769
02/05/11 10:33 PM
02/05/11 10:33 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i just aquired a low mile 09 hemi replacement long block complete engine.. where is a good place to learn about tricks for the new hemi's i thinking of stroked with a power adder for the drag only duster... rignt now its a complete running motor. i dont know if i should keep the efi or go something else..? who knows what and where to learn up.. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
Re: 3rd gen HEMI swap for drag racing...tricks for power.
[Re: Kiddart]
#921771
02/05/11 11:00 PM
02/05/11 11:00 PM
cheapstreetdustr
can i run a 727 with it or do i need the hemi transmission? i have it...but had planned on using the 727? cheapst
[Re: cheapstreetdustr]
#921772
02/05/11 11:07 PM
02/05/11 11:07 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
3rd Gen Hemi's have the small block bell housing bolt pattern. Mopar makes a flex plate for mating to the converter. Check out www.lxforums.com. There are a ton of vendors that support the site & offer parts for 3rd Gen Hemi's.
[Re: STEFF]
#921774
02/05/11 11:17 PM
02/05/11 11:17 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
i am interested as well. With the heads capable of big cfm compared to an average small block head, they seem to be an interesting alternative to run of mill engine builds. i think they are an alternative.
i think a drag pak intake may be beneficial, but could be costly.
if it is an 09 engine, you have one piece to the puzzle, which are the eagle casting heads, that flow well for OEM castings.
justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
#921775
02/05/11 11:18 PM
02/05/11 11:18 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
We just did a 6.1L super stock legal engine for a customer of ours & almost made 700 HP N/A. 689/586 to be exact. Not bad.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
#921776
02/05/11 11:47 PM
02/05/11 11:47 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I don't think there are any cams out yet for the 09 hemi as it uses a very different drive set up for the variable cam timing. The heads are almost as good as it gets. I have heard of 440 inch gen III hemis and people are running them at 700 hp on routine basis and I have not heard of a block failure yet on either the 6.1 or 5.7.
[Re: wldtm]
#921777
02/06/11 12:03 AM
02/06/11 12:03 AM
STEFF
About $1000, if you can find one.
[Re: sam64]
#921781
02/06/11 12:24 PM
02/06/11 12:24 PM
cheapstreetdustr
so do i need a differnt block short block? or can i delete the vvt cam set up? i want to stroke it..what cranks are available? are these cyl bores able to be bored? or is the finish on them too hard? if so..how big from 3.90 can i go? cheapst
[Re: S/ST 3040]
#921784
02/06/11 02:51 PM
02/06/11 02:51 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
If I was going to build a late model HEMI (and I might) to race, I'd get ahold of board member, gremlinsteve. It seems he was the guy doing these for a while now.
I heard, at some point there was supposed to be an aluminum block built for race purposes but, haven't seen/heard of anything recently.
Just before Christmas I received an email from Mopar news saying the aluminum blocks were great Christmas presents at almost $10,000, LOL http://www.bouchillonperformance.com/61LHemiAluminumBlocks.asp
[Re: S/ST 3040]
#921785
02/06/11 04:01 PM
02/06/11 04:01 PM
STEFF
I talked to gremlinsteve....nice dude!! And, very knowledgeable.
[Re: S/ST 3040]
#921786
02/06/11 09:26 PM
02/06/11 09:26 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Aluminum block are out there but they are at 4600.00 Matt
#921788
02/07/11 03:39 PM
02/07/11 03:39 PM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
'08-down 5.7 has near unlimited aftermarket cam support.
'09-up 5.7 has basically no aftermarket cam support at all, unless you include the welded up, reground stock cams that are floating around out there....
It's not easy to delete the vvt from a 2009-up 5.7 shortblock because the front cam journal is huge, much bigger than the old style cam. The old style cam would fall right through the hole in the block....and as said the drive is different also.
It's much easier to get a 2008 or earlier 5.7, or a 6.1, and start with that instead.
Rich H.
Esse Quam Videri
