Re: Drive shaft ---- Aluminum VS Chrome Moly
[Re: blown572dart]
#919561
02/03/11 12:06 AM
02/03/11 12:06 AM
We run a 4" with 1480 joints from Bickel.
A 4" what? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: ]
#919562
02/03/11 12:35 AM
02/03/11 12:35 AM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
A 4" what?
Chromoly (sorry) ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: blown572dart]
#919563
02/03/11 01:02 AM
02/03/11 01:02 AM
Posts: 4,292 Morrow, OH
markz528
Morrow, OH
I have a long shaft and make around 800 hp. I was really close to critical speed with the quoted chrome moly shaft, and Mark Williams talked me into a mild steel 4 inch. I used to pass through a critical speed with the 3 1/2 inch shaft, but the 4 inch is nice and smooth through the whole range, and that was up to 7400 rpm at one time.
[Re: Super Scamp]
#919565
02/03/11 10:43 AM
02/03/11 10:43 AM
Posts: 642 New Jersey
Craig
New Jersey
One other thing to consider is damage resistance - if you accidentally hit it with a tool or jackstand, chrome moly won't be affected, but aluminum or carbon fiber may get nicked and then fail at that point.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: Craig]
#919566
02/03/11 10:55 AM
02/03/11 10:55 AM
Posts: 694 Michigan
Super Scamp
It's good to hear from all the members that are running above 800hp with different shafts installed in their Mopars. Good information and correct information is hard to come by these days. Thanks
Dyno Tech has built my Alum. 3 1/2 with 1350 joints I have billet front and rear yokes. I should be ok to launch the beast this spring.
Just One Man's Opinion
Mopar Mafia Racing
[Re: bill_greenwood]
#919567
02/03/11 11:08 AM
02/03/11 11:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Not to hijack this, but what kind of ET gains are likely to be seen when going from a stock-style drive shaft to a CM or alum. one? The one behind my little torque-challenged small block is the stock one with the 9" u-joint added.
I dont think you will see any change... I went moly from day one so I dont have any comparison... but my way of thinking is if you go alum you need to add diameter to get the strength but you also loose a few pounds but you also move the weight farther out from centerline so I believe thats a wash... JMO.... rule of thumb is you need 2X the wall thickness over steel to be the same strength... but if you increase diameter it add strength... but again you move the weight outward which is harder to turn(accelerate)... I'm sure when its all said and done its all a wash ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 440Jim]
#919568
02/03/11 11:14 AM
02/03/11 11:14 AM
Posts: 8,165 Left Coast
BobR
Left Coast
That sounds backwards - aluminum stays stretched (rods), steel relaxes back.
![](/ubbthreads/images/graemlins/iagree.gif) Wall thickness and diameter are the design parameters for torque. If designed to stay under the fatique limit, the steel will have unlimited life. Aluminum has no fatique limit, it will always fatigue at any stress; it is just a matter of time.
I agree completely. We use a steel shaft on our 3000 HP combination. We used a carbon fiber unit with our 2000 HP nitrous deal.
