Re: 5.2 EFI swap into E body suggestions?
[Re: Andrewh]
#918175
03/20/11 11:40 PM
03/20/11 11:40 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
the gentlemen with the fury in the pic wasnt going to do that. we made our own harness. we just posted pics to this thread because he was doing something similar to the 5.2 in the E body. this car (gold fury) used factory dakota wiring harness modified and the 5.2. he is trying to do this as simple as possible. justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: ralphie361]
#918177
03/23/11 01:21 AM
03/23/11 01:21 AM
Posts: 1,179 Canada
demon
Canada
Fired the car up for the first time tonight! Plugged in most of the harness, and tapped 12V off of the alternator and 12v ignition on source off of the old coil wire, temporarily. If you take out the ballast resistor and jumper the terminals you get full 12V on start and run position in the ignition switch. Still did not plumb a fuel system, just running it off of a pressurized tank for the moment. Now for permanent wiring since I know it works. Thanks to Justin (wldtm) for all of his help on this car
excellent! I'd sure like to know what wires are necessary for making the engine and computer function so I can retain my stock dash etc if I go that way. Nice job!
[Re: demon]
#918178
03/23/11 08:13 AM
03/23/11 08:13 AM
wldtm
Dayton, Ohio
Keep these PINs per a 94 dakota service manual
PINS 1 map sensor 2 ECT sensor 3 Battery feed 4 sensor return 6 5v supply 7 8v supply 9 Ignition feed 10 not needed with 727 11 Ground 12 Ground 13 Inj Driver4 14 Inj Driver3 15 Inj Driver2 16 Inj Driver1 17 Inj Driver7 18 Inj Driver8 19 Ign Coil Driver 20 Gen Feild Driver 21 Air Temp Sensor 22 TP Sensor 24 Reference Pickup 25 Data link 27 AC compressor (if keeping AC) 29 Brake sense (if keeping cruise) 30 P/N switch 32 MIL 33 VSS (if keeping dakota cruise) we got rid of) 34 AC WOT relay (if keeping ac- we got rid of) 35 EGR Solenoid (we deleted EGR) 37 Trans OD light (we got rid of) 38 Inj Driver5 39 IAC 40 IAC 41 Heated O2 Sensor 43 Tach (we kept) 44 CMP sensor 45 Data llink 47 VSS pick up (we kept for now) KEEP 47-50, 53 keep if using dakota cruise 48 VSS set/coast (we got rid of) 49 VSS on/off (we got rid of) 50 VSS resume/accel 51 ASD relay and fuel pump relay driver 52 Evap purge (we got rid of) 53 VSS vent (we got rid of) 54 EMCC solenoid (we got rid of) 55 Trans OD solenoid (we got rid of) (keep if using 42rh or 46rh) 57 ASD bat supply 58 Inj Driver6 59 IAC 60 IAC
The best thing to do is build a wiring harness using a 94-95 dakota schematic. You will need an ASD and fuel pump relay socket. This is the part where you will need to do a little modifying.
It depends on how much stuff you want to keep. You could keep AC, overdrive trans, and cruise if you wanted to...
Use the vehicles stock sending unit to run gauges ex) temp, oil psi, volts
I can make this harness for interested parties
PM for details
[Re: ralphie361]
#918180
03/26/11 10:57 PM
03/26/11 10:57 PM
Andrewh
Found an oversight in my parts selection this afternoon. 5.2 and 5.9 magnums use the same oil pan, not like 318 vs 360 LA. When I first filled it with oil I had a leak and chalked it up to me screwing up the gasket install. After the second one this afternoon leaked I looked it up online and got conflicting stories. MP tech line confirmed that I need a 360 car pan instead of the 318 pan for the 5.2 or 5.9, and they said the one piece rubber gasket should work. Minor issue, but annoying!
the one piece does not work. I know. unless you adjust the pan, it will leave a gap at the front and back of the motor. you need to use the LA gasket set.
