440 Windage Tray #917086
01/30/11 12:39 PM
01/30/11 12:39 PM
Cannelton, IN
mike337 Offline OP
mike337  Offline OP
Cannelton, IN
I want to add a windage tray to my 440 which is now being rebuilt, but I am concerned that the stock oil pan bolts will not be long enough to really secure the added depth of the 2nd gasket and windage tray. Are there slightly longer bolts available that don't come from the corner hardware store?
Re: 440 Windage Tray [Re: mike337] #917087
01/30/11 12:53 PM
01/30/11 12:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You'll be fine with what you have.
Re: 440 Windage Tray [Re: mike337] #917088
01/30/11 12:57 PM
01/30/11 12:57 PM
scratchnfotraction Offline
I run a stock windage tray/oil pan with 2 cork gaskets
stock bolts are fine,just dont crush/squeeze the gaskets out by over torqueing
I run a thin coat of copper rtv on both my gaskets and let cure over night before running engine
you can go to oil pan studs if you dont like the stock bolts,very nice when its on the engine stand and fliped upside down for the pan install
make sure to check oil pick up tube and bottom of the pan for correct placement
I had to tweak my pick up tube just slightly to clear the tray in one spot
double check before it goes in the car/truck
Re: 440 Windage Tray [Re: 62maxwgn] #917089
01/30/11 02:45 PM
01/30/11 02:45 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Just dont waste money on the MP tray.Get the Milidon one.Much better piece.Rocky
Chrysler Firepower
Re: 440 Windage Tray [Re: therocks] #917090
01/30/11 03:04 PM
01/30/11 03:04 PM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
The MIlodon has better drain back features (cutouts). I just drilled a couple of holes in the Factory piece since I already had it. I also used Permatex High Tack on the cork gaskets. No leaks in 9+ years.
Re: 440 Windage Tray [Re: therocks] #917091
01/30/11 11:54 PM
01/30/11 11:54 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Ride eternal, shiny and chrome
Re: 440 Windage Tray [Re: DirectSubjection] #917092
01/31/11 12:46 AM
01/31/11 12:46 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
yep,just like everything else those chrysler engineer's designed,didn't have a clue what they were doing.
Re: 440 Windage Tray [Re: 62maxwgn] #917093
01/31/11 12:51 AM
01/31/11 12:51 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
440 Source tray is very nice,cheaper than the Milodon and made in the U.S.A.
Leave the gun.......take the Cannoli's....Mike
Re: 440 Windage Tray [Re: mike s] #917094
01/31/11 01:18 AM
01/31/11 01:18 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
+50 on the Milodon. Unless your corner hardware store sucks their bolts should be fine for an oil pan. It isn't like they are rod bolts.
