Re: 1969 Charger R/T - Let the journey begin
[Re: NewbombTurkk]
#916486
02/03/11 07:19 PM
02/03/11 07:19 PM
Posts: 21,798 It's a dry heat
gtx6970
It's a dry heat
Hard to say, and I don't have the original estimate handy. But we're already into things that wasn't on the original estimate. My job was to do the disc brake conversion , get it running and complete the underhood area. but we're already past that
but with the unknowns with the engine it was felt best to pull it apart now and investigate as opposed to later when everything was done.
Why do you ask,,,,,,,,??? pm me if you prefer
[Re: gtx6970]
#916490
02/14/11 09:50 AM
02/14/11 09:50 AM
gtx6970
It's a dry heat
Another view of the redone a/c components.
[Re: BTTG]
#916493
02/14/11 04:35 PM
02/14/11 04:35 PM
gtx6970
It's a dry heat
Is that high pressure power steering hose new? If so where'd you get it?
Yes, I got it thru my local parts jobber. I laid it out next to the original and it looks just like it except plating color and #'s stamped on the crimped ends
I'm sure you can get it thru any decent auto parts store
[Re: gtx6970]
#916498
02/16/11 09:29 PM
02/16/11 09:29 PM
gtx6970
It's a dry heat
I couldn't find a new weight or a new shaft, so I had to re-use the originals.
[Re: gtx6970]
#916505
06/17/11 11:30 PM
06/17/11 11:30 PM
gtx6970
It's a dry heat
long overdue update. I've been working on it here and there, but the past week I've been hitting it pretty steadily
Rebuilt the original single point dist, added some lighter spings for the advance. With NOS points and condensor, nos original tan dist cap and rotor, and even picked up an nos vacuum advance unit.
