Page 2 of 3 1 2 3
Re: 1969 Charger R/T - Let the journey begin [Re: NewbombTurkk] #916486
02/03/11 07:19 PM
02/03/11 07:19 PM
It's a dry heat
gtx6970 Online content OP
gtx6970  Online Content OP
It's a dry heat
Hard to say, and I don't have the original estimate handy. But we're already into things that wasn't on the original estimate.
My job was to do the disc brake conversion , get it running and complete the underhood area. but we're already past that
but with the unknowns with the engine it was felt best to pull it apart now and investigate as opposed to later when everything was done.
Why do you ask,,,,,,,,???
pm me if you prefer
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916487
02/14/11 09:05 AM
02/14/11 09:05 AM
It's a dry heat
It's a dry heat
Got all the long missing A/C compressor brackets and pulleys located, redone and installed . A better and more correct water pump idler pulley and bracket are located and enroute to me now.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916488
02/14/11 09:10 AM
02/14/11 09:10 AM
It's a dry heat
It's a dry heat
It's a new power steering pump. Glass beaded and re-used the original pump reservoir can and pulley.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916489
02/14/11 09:43 AM
02/14/11 09:43 AM
It's a dry heat
It's a dry heat
I also found all the pieces to repair the heat riser.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916490
02/14/11 09:50 AM
02/14/11 09:50 AM
It's a dry heat
It's a dry heat
Another view of the redone a/c components.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916491
02/14/11 09:57 AM
02/14/11 09:57 AM
It's a dry heat
It's a dry heat
Downward view of the 1969 Only A/C compressor brackets
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916492
02/14/11 10:19 AM
02/14/11 10:19 AM
PA
BTTG Offline
BTTG  Offline
PA
Is that high pressure power steering hose new? If so where'd you get it?
Re: 1969 Charger R/T - Let the journey begin [Re: BTTG] #916493
02/14/11 04:35 PM
02/14/11 04:35 PM
It's a dry heat
It's a dry heat
Yes, I got it thru my local parts jobber. I laid it out next to the original and it looks just like it except plating color and #'s stamped on the crimped ends
I'm sure you can get it thru any decent auto parts store
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916494
02/16/11 09:13 PM
02/16/11 09:13 PM
It's a dry heat
It's a dry heat
Well, I had to take advantage of the help while I had it today.
So, in it went.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916495
02/16/11 09:14 PM
02/16/11 09:14 PM
It's a dry heat
It's a dry heat
And like Prego, it's in there.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916496
02/16/11 09:25 PM
02/16/11 09:25 PM
It's a dry heat
It's a dry heat
I had to find pieces to repair the heat riser. Not to bad of a job, now just need to weld it back together.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916497
02/16/11 09:27 PM
02/16/11 09:27 PM
It's a dry heat
It's a dry heat
Other side with the bi-metal spring
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916498
02/16/11 09:29 PM
02/16/11 09:29 PM
It's a dry heat
It's a dry heat
I couldn't find a new weight or a new shaft, so I had to re-use the originals.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916499
02/16/11 09:31 PM
02/16/11 09:31 PM
It's a dry heat
It's a dry heat
last one
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916500
03/03/11 06:51 PM
03/03/11 06:51 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Very nice
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1969 Charger R/T - Let the journey begin [Re: BloFish] #916501
03/07/11 10:15 AM
03/07/11 10:15 AM
At a gas station near you
badblack68 Offline
badblack68  Offline
Looking great! Love the color combo.
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916502
04/04/11 09:36 AM
04/04/11 09:36 AM
It's a dry heat
It's a dry heat
A few pieces I had plated came back last week.
Everything was done by Neil at Dynamic Renovation
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916503
04/04/11 09:37 AM
04/04/11 09:37 AM
It's a dry heat
It's a dry heat
2
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916504
04/04/11 09:38 AM
04/04/11 09:38 AM
It's a dry heat
It's a dry heat
3
Re: 1969 Charger R/T - Let the journey begin [Re: gtx6970] #916505
06/17/11 11:30 PM
06/17/11 11:30 PM
It's a dry heat
It's a dry heat
long overdue update. I've been working on it here and there, but the past week I've been hitting it pretty steadily
Rebuilt the original single point dist, added some lighter spings for the advance. With NOS points and condensor, nos original tan dist cap and rotor, and even picked up an nos vacuum advance unit.
Page 2 of 3 1 2 3
