Powdercoating in Pittsburgh?? #916448
01/29/11 03:15 PM
01/29/11 03:15 PM
PA
dodgeman316 Offline OP
PA
Can anyone recommend a company that does good powdercoating for a reasonable price in the Pittsburgh area?
I am a little south of Pittsburgh not far from Washington, PA.
I am looking to get the rear axle, k-frame etc. done.
Anyone run into problems with powdercoating swaybars? Not sure if they would twist enough to cause a problem with the coating. I am thinking they would probably be ok.
Greg
1969 Super Bee
Re: Powdercoating in Pittsburgh?? [Re: dodgeman316] #916449
01/29/11 11:45 PM
01/29/11 11:45 PM
, PA
sleepyhead416 Offline
, PA
There's a place I used cant remeber name by Northstar bar by Pa motor speedway. Prizm rings a bell. Off rt 22 by Imperial
Re: Powdercoating in Pittsburgh?? [Re: sleepyhead416] #916450
01/30/11 11:56 AM
01/30/11 11:56 AM
PA
PA
Thanks for the reply sleepyhead, I'll see if I can find some more info on them.
I was hoping to get a recommendation for companies in the area that someone has used recently that did a nice job.
It would be even better if they were somewhat familiar with Mopar factory colors and gloss levels.
Re: Powdercoating in Pittsburgh?? [Re: dodgeman316] #916451
01/30/11 01:54 PM
01/30/11 01:54 PM
Charlotte NC
DCI Offline
DCI  Offline
Charlotte NC
http://www.customcoaters.com/html/pennsylvania.html
A couple of pages...cities are in alphabetical order after the banner ones.
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block." Those words must have left a bad taste in his mouth!
