manually setting the total advance limit
#913509
01/25/11 11:12 AM
01/25/11 11:12 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. Anyone have a method they use to manually limit the amount of total advance the counter-weights will produce in their OEM Chrysler distributors? I'm looking to do some experimentation. Seasoned Mopar builder once told me our big block mopars like more initial curb idle advance (somewhere like 14 degrees). With that though, you have a tendency to produce higher than desired total degrees after final inertial movement by the weights. If I had a way to limit the movement of the weights within their slots, I could possible achieve this... I'm looking to modify a traditional points distributor, with and without a Pertronix kit. May try this experiment on one of my dual-point Prestolites as well...
Thanks in advance...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: manually setting the total advance limit
[Re: hemi68charger]
#913510
01/25/11 11:57 AM
01/25/11 11:57 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
Not really easy as far as i know it can be done but it will take a lot of time and effort. What has to happen is spin on a machine or in the engine with a dial back timming light and record the base setting . Then remove the distributor and gas braze the slots smaller and spin on machine to see how much change is made then file the slots where welded until you get them where u like the advance limit total . This used to be done at shops that specialized in distributor re-curving for a nominal price . If it were me i would just buy a new Mopar distributor because the slots in the MP one are adjustable and the keys from a Mallory distributor will work to set the amount advance limit . FYI i run 20 deg initial @950 rpm and total of 38deg starting at 1000 rpm all in by 2100 rpm this is what works best on my engine . it has taken me 4 years of tinkering with it at home to fully understand this ....and get it right .
1969 Dodge Charger
1969 Dodge Superbee
[Re: express]
#913512
01/25/11 12:28 PM
01/25/11 12:28 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
A friend did this on my small block. He used braze rod, it's strong enough for the application, and easy to file. ![](/ubbthreads/images/graemlins/Twocents.gif) I ran 18 initial and 36 total.
[Re: hemi68charger]
#913513
01/25/11 12:51 PM
01/25/11 12:51 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
....or you could send your unit to FBO and get their ignition kit. Easy, proven and relatively inexpensive.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#913515
01/25/11 12:58 PM
01/25/11 12:58 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
I think FBO has a plate that drops in over the slots to limit advance , since Troy will be using a pertronix it makes no sense to send the dist to FBO and/or get their ignition kit.
[Re: JohnRR]
#913516
01/25/11 01:31 PM
01/25/11 01:31 PM
hemi68charger
Houston, Tx
I was just reading that John, looks interesting to experiment for sure. I could add it to my existing set-ups I will eventually have and get the best of all worlds...
Is this what you're talking about?
[Re: JohnRR]
#913517
01/25/11 01:32 PM
01/25/11 01:32 PM
Posts: 3,908 Oregon
hooziewhatsit
Here ya go ![](/ubbthreads/images/graemlins/beer.gif) Pull the distributor apart, then weld the slots shut to get the total length corresponding to the advance you want. Before doing that, I would find your ideal initial by advancing the timing to get max vacuum, then backing it off 1"hg. Someone else recommended to weld up the inside of the slots, so the light springs have a little preload on them, rather than welding the outside of the slots. dist. degrees X 2 + initial= total dist. degrees / slot size 6.............. .340 7............... .355 8............... .375 9............... .390 10.............. .405 11.5 ........... .420 12.............. .435 13.............. .445 14.............. .460 15.............. .475 16.............. .490 17.............. .505 18.............. .520
[Re: hemi68charger]
#913518
01/25/11 04:34 PM
01/25/11 04:34 PM
JohnRR
Yes that's it , I may get one to put in my Dual point to limit mechanical without having to weld on my original A body 383 dual point.
[Re: six-barrel]
#913520
01/25/11 08:35 PM
01/25/11 08:35 PM
hemi68charger
Houston, Tx
Whats your cam spec @50, this generally dictates what your initial timing should be.
The motor is a bone stock OEM '69 Chrysler New Yorker 440... Now in a '69 Charger 500 with a 440 six pack on it.... Who would have figured? ![](/ubbthreads/images/graemlins/grin.gif)
[Re: hooziewhatsit]
#913521
01/25/11 08:54 PM
01/25/11 08:54 PM
RapidRobert
Pull the distributor apart, then weld the slots shut to get the total length corresponding to the advance you want. Before doing that, I would find your ideal initial by advancing the timing to get max vacuum, then backing it off 1"hg. dist. degrees X 2 + initial= total
What Hoozie said, (1) find the ideal initial for YOUR individual combo (w eng warmed up) then w that figure in hand braze then file the slots to get (2) 36-38 total (BB).(3) Play w the springs staying just under the pinging point at WOT up thru the gears then (4) then vac adv (if used) staying just under the pinging point at PART throttle (light throttle/high vacuum) at or above the RPM where the springs (total) are maxed out & can adj (A) WHEN the slope starts (& therefore ends) and (B) can solder feeler gauge strips on either side of the notch in the arm to limit the AMOUNT of advance. You have to open it up to add the FBO plate which only has so many selections so you might as well open it up & braze/file it & get it spot on
[Re: hemi68charger]
#913522
01/26/11 12:08 PM
01/26/11 12:08 PM
JohnRR
Must not be very impressive with that 383 2bbl cam in it ?
[Re: JohnRR]
#913523
01/26/11 12:37 PM
01/26/11 12:37 PM
hemi68charger
Houston, Tx
![](/ubbthreads/images/graemlins/haha.gif)
No clue.. It's still on jack-stands and will be there for a bit. It's a major accomplishment to just get it started. Now it's on to the tranny to make sure it works properly and then begin on the brakes. One step at a time. I'll be happy that it's running, whether or not it's a putt-putt motor or an Elephant. With the 4.10 Dana in it, I believe she'll get out of her way. Eventually, I can make internal changes... I'll be happy just to go to the grocery store or Lowes in my'69 Charger 500. Plus, I'm hoping my wife will like it and drive it. Can't get her to drive the Daytona...........
[Re: hemi68charger]
#913524
01/26/11 02:02 PM
01/26/11 02:02 PM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
Troy, There was a good thread on this some time ago. old thread I welded up and filed my dual point distributor slots to the dimensions on that chart for the Hemi and it worked out sweet. Jim
[Re: 68jim]
#913525
01/26/11 03:46 PM
01/26/11 03:46 PM
hemi68charger
Houston, Tx
Troy,
Thanks Jim,,, I appreciate it.. From the above chart, if I'm interpreting it correctly, does this make sense:
10(.405) x 2 + 14 = 34
If I wish to run my car with an initial curb idle timing of 14 degrees but only go to 34 total mechanical (with vacuum hooked up), the slot needs to be no bigger than .405 inches.
This make sense?
The vacuum advance pod hooked up will give me the increased timing based on increased throttle movement. If I wish for the timing to "kick" in earlier, then I'd need to swap one of the weight springs to a lighter one...
[Re: hemi68charger]
#913526
01/26/11 03:59 PM
01/26/11 03:59 PM
Posts: 3,908 Oregon
hooziewhatsit
This make sense?
Yes, that is how the timing will work; initial + mechanical = total (34* in your example).
Vac advance will only come into play at high vacuum, low throttle times (ie, cruise down the highway), and will add another 10-20* on top of the total, so you'll be in the ballpark of 55*.
With the engine running, you can see the timing curve easily if you have a timing tape on the balancer. As you rev it up, you'll be able to see the timing advance until it gets to the total, then it will stop advancing. You also want strong enough springs that it doesn't start advancing the timing until you're a couple hundred RPMs higher than your idle speed.
[Re: RapidRobert]
#913528
01/26/11 05:06 PM
01/26/11 05:06 PM
hemi68charger
Houston, Tx
10(.405) x 2 + 14 = 34 If I wish to run my car with an initial curb idle timing of 14 degrees but only go to 34 total mechanical (with vacuum hooked up), the slot needs to be no bigger than .405 inches....
You would want to get your 34 amount w the vac can line unhooked/plugged then plug it in & 34 is a bit low.
Cool.. Thanks... I was just using the 34 as a mathmatical example. I would probably go 36-38 total......... Just making sure I have the theory down.
