Re: manually setting the total advance limit
[Re: SomeCarGuy]
#913530
01/26/11 06:44 PM
01/26/11 06:44 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
34 isn't necessarily too low. I tried 36 and 38 and the car didn't run very good. Couldn't hear any pingin but I suspect silent knock. 34 ended up being very it runs smooth. I have a stock 383 HP and we have decent pump gas here. For now anyway
When I ran at the Pure Stock drags the people I talked to said to run as much as 42 on my 69 383HP , my engine was stock so compression was only 9.2ish , I compromised and ran it at 40 , and mixed some race gas in with the 93 I already had in the tank , it did pick up MPH after doing that.
[Re: JohnRR]
#913533
01/26/11 09:56 PM
01/26/11 09:56 PM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
In my iron headed 440, the more timing I put in it, the faster it went. End up in the 40 to 42 range, mostly because I was concerned about going any further.
