70 hp440 ???? #912925
01/24/11 04:17 PM
01/24/11 04:17 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
okay I have an 440 hp motor with an casting date of 11/23/69 & a date code on pad for assy. date of F which is 1970 so my question is on balancing is the 69 440 motor balanced the same or Is one internal bal& one external I am confused I am wanting to use a 11" 143 tooth flywheel tht I have but I believe it is not balanced ????? so would this be a 70 or 69 internal motor?? is there any diff.
Re: 70 hp440 ???? [Re: AB&E] #912926
01/24/11 04:20 PM
01/24/11 04:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the casting date on the side of the block is just that , the date the block was cast , nothing more , nothing less and in the grand scheme is MEANINGLESS .
The important data is the info STAMPED on the ID pad , it has an F , 1970 model year and it's an HP , 1970 model year 440 HP's are EXTERNAL BALANCE ASSuMEing that it is still as it left the factory ? What balancer is on the front of the engine , internal or external ?
Re: 70 hp440 ???? [Re: JohnRR] #912927
01/24/11 04:37 PM
01/24/11 04:37 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
dont know the diff.??is the 69 motor balanced the same. & if so will this flywheel work on this app.
Re: 70 hp440 ???? [Re: AB&E] #912928
01/24/11 04:40 PM
01/24/11 04:40 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
69 440 Hp is internally balanced and used 11" flywheel...70 440 HP is externally balanced and used a 10 1/2" flywheel....also different crank dampers
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 hp440 ???? [Re: JohnRR] #912929
01/24/11 04:40 PM
01/24/11 04:40 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
Yoyu
The important data is the info STAMPED on the ID pad , it has an F , 1970 model year and it's an HP , 1970 model year 440's are EXTERNAL BALANCE ASSuMEing that it is still as it left the factory ? What balancer is on the front of the engine , internal or external ?
I believe that you meant to state that the 70 engines were internally ballanced.
Re: 70 hp440 ???? [Re: repad] #912930
01/24/11 05:07 PM
01/24/11 05:07 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
I was told steel crank all the way up to 71-72 if not changed out & dampener is the clue so I am still confused looking for answers so it sounds like if my crank in my 70 hp motor is stock then the 11" flywheel will work because notors are balanced the same????? which is external or internal? I mnow its monday & my brain is toast
Re: 70 hp440 ???? [Re: AB&E] #912931
01/24/11 06:21 PM
01/24/11 06:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
NO the 69 motor is not balnced the same .
Re: 70 hp440 ???? [Re: AB&E] #912932
01/24/11 06:23 PM
01/24/11 06:23 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
so any other input I have been told that 69-70 hp 440 balanced the same from my local repair mopar guy. which is diff. from what I am being told here????
Re: 70 hp440 ???? [Re: repad] #912933
01/24/11 06:23 PM
01/24/11 06:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yoyu
NO , I didn't , read what you quoted , and I just put in BOLD though I should have put HP after 440 above just like I did to not add confusion , which it seems I did
Re: 70 hp440 ???? [Re: AB&E] #912934
01/24/11 06:27 PM
01/24/11 06:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Your local guy is wrong , 70 440 NON HP is balanced the same as the 69which is INTERNAL , 70 440 HP and 6pk are EXTERNAL BALANCED , if your 143 tooth flywheel is neutral balanced it WILL NOT WORK PROPERLY ... again ASSUMING that the 70 motor you have is FACTORY ORIGINAL STILL.
Re: 70 hp440 ???? [Re: JohnRR] #912935
01/24/11 06:39 PM
01/24/11 06:39 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
okay so lets say my 70 440hp is stock can I use my 69 11" bellhousing & which flywheel would I use? using an 23 spline tranny
thanks marty l so tell me again 69 is internall & 70 is external i am a little slow sometimes
Re: 70 hp440 ???? [Re: AB&E] #912936
01/24/11 08:32 PM
01/24/11 08:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A little ? if you were any slower on this you would be back in the womb ....
kidding ...
Yes you can use the 69 bellhousing on it , but you have to use an external balance 143 tooth flywheel and there wasn't one from the factory. But, lets not ASSuME it's stock. Do you know for a FACT that it is a factory stock never been monkeyed with engine ?
Re: 70 hp440 ???? [Re: JohnRR] #912937
01/24/11 08:36 PM
01/24/11 08:36 PM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
Post a picture of the balancer and we will know what you have. If
nothing internal has been changed.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: 70 hp440 ???? [Re: JohnRR] #912938
01/24/11 09:37 PM
01/24/11 09:37 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
kidding ...
thanks its monday so I am running only on 3cyl.
I will try to take pic tonight of balancer.
Re: 70 hp440 ???? *DELETED* [Re: stickman] #912939
01/25/11 01:28 AM
01/25/11 01:28 AM
washington
AB&E Offline OP
AB&E  Offline OP
washington
Post deleted by AB&E
Re: 70 hp440 ???? *DELETED* [Re: AB&E] #912940
01/25/11 01:32 AM
01/25/11 01:32 AM
washington
AB&E Offline OP
AB&E  Offline OP
washington
Re: 70 hp440 ???? [Re: AB&E] #912941
01/25/11 01:40 AM
01/25/11 01:40 AM
washington
AB&E Offline OP
AB&E  Offline OP
washington
also here is the partial vin any idea what motor was in originally.
0 215237 cast date 11/06/69
pad info f440 A
1-23
thanks for info
Re: 70 hp440 ???? [Re: AB&E] #912942
01/25/11 01:49 AM
01/25/11 01:49 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The 70 HP 440 used the heavy 6-pack rods and was externally balanced with a dampner with extra weight on it. See the photo in this post:
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: 70 hp440 ???? [Re: 451Mopar] #912943
01/25/11 02:20 AM
01/25/11 02:20 AM
washington
AB&E Offline OP
AB&E  Offline OP
washington
well I see my pics fizzled
I believe thats what mine looks like I do have holes drilled on the side also
Re: 70 hp440 ???? [Re: AB&E] #912944
01/25/11 09:09 PM
01/25/11 09:09 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
pad info f440 A
1-23
thanks for info
Is this someones 70hp440 thats missing on here?? I could sale it
