Re: 70 hp440 ????
[Re: AB&E]
#912931
01/24/11 06:21 PM
01/24/11 06:21 PM
Posts: 75,046 U.S.S.A.
JohnRR
U.S.S.A.
dont know the diff.??is the 69 motor balanced the same. & if so will this flywheel work on this app.
NO the 69 motor is not balnced the same .
Re: 70 hp440 ????
[Re: AB&E]
#912932
01/24/11 06:23 PM
01/24/11 06:23 PM
Posts: 204 washington
AB&E
washington
I was told steel crank all the way up to 71-72 if not changed out & dampener is the clue so I am still confused looking for answers so it sounds like if my crank in my 70 hp motor is stock then the 11" flywheel will work because notors are balanced the same????? which is external or internal? I mnow its monday & my brain is toast
so any other input I have been told that 69-70 hp 440 balanced the same from my local repair mopar guy. which is diff. from what I am being told here????
Re: 70 hp440 ????
[Re: repad]
#912933
01/24/11 06:23 PM
01/24/11 06:23 PM
JohnRR
U.S.S.A.
YoyuQuote:
okay I have an 440 hp motor with an casting date of 11/23/69 & a date code on pad for assy. date of F which is 1970 so my question is on balancing is the 69 440 motor balanced the same or Is one internal bal& one external I am confused I am wanting to use a 11" 143 tooth flywheel tht I have but I believe it is not balanced ????? so would this be a 70 or 69 internal motor?? is there any diff.
the casting date on the side of the block is just that , the date the block was cast , nothing more , nothing less and in the grand scheme is MEANINGLESS .
The important data is the info STAMPED on the ID pad , it has an F , 1970 model year and it's an HP , 1970 model year 440 HP's are EXTERNAL BALANCE ASSuMEing that it is still as it left the factory ? What balancer is on the front of the engine , internal or external ?
I believe that you meant to state that the 70 engines were internally ballanced.
NO , I didn't , read what you quoted , and I just put in BOLD though I should have put HP after 440 above just like I did to not add confusion , which it seems I did
Re: 70 hp440 ????
[Re: AB&E]
#912934
01/24/11 06:27 PM
01/24/11 06:27 PM
JohnRR
U.S.S.A.
Your local guy is wrong , 70 440 NON HP is balanced the same as the 69which is INTERNAL , 70 440 HP and 6pk are EXTERNAL BALANCED , if your 143 tooth flywheel is neutral balanced it WILL NOT WORK PROPERLY ... again ASSUMING that the 70 motor you have is FACTORY ORIGINAL STILL.
Re: 70 hp440 ????
[Re: AB&E]
#912936
01/24/11 08:32 PM
01/24/11 08:32 PM
JohnRR
U.S.S.A.
okay so lets say my 70 440hp is stock can I use my 69 11" bellhousing & which flywheel would I use? using an 23 spline tranny thanks marty l so tell me again 69 is internall & 70 is external i am a little slow sometimes
A little ? if you were any slower on this you would be back in the womb ....
kidding ...
Yes you can use the 69 bellhousing on it , but you have to use an external balance 143 tooth flywheel and there wasn't one from the factory. But, lets not ASSuME it's stock. Do you know for a FACT that it is a factory stock never been monkeyed with engine ?
Re: 70 hp440 ????
[Re: JohnRR]
#912937
01/24/11 08:36 PM
01/24/11 08:36 PM
Posts: 1,191 imperial mo.
stickman
imperial mo.
Post a picture of the balancer and we will know what you have. If nothing internal has been changed.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: 70 hp440 ????
[Re: JohnRR]
#912938
01/24/11 09:37 PM
01/24/11 09:37 PM
AB&E
washington
kidding ...
thanks its monday so I am running only on 3cyl. I will try to take pic tonight of balancer.
Re: 70 hp440 ????
[Re: AB&E]
#912941
01/25/11 01:40 AM
01/25/11 01:40 AM
AB&E
washington
also here is the partial vin any idea what motor was in originally. 0 215237 cast date 11/06/69 pad info f440 A 1-23 thanks for info
Re: 70 hp440 ????
[Re: AB&E]
#912944
01/25/11 09:09 PM
01/25/11 09:09 PM
AB&E
washington
thanks for info
Is this someones 70hp440 thats missing on here?? I could sale it
