Page 16 of 16 1 2 14 15 16
Re: 430" small block build [Re: Streetwize] #912922
12/16/12 10:28 PM
12/16/12 10:28 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Wize - I found that the torque curve stayed similar - all had around 560 fy lb peaks, but they moved up as the cam / head / intake setup went up.
My testing was more focused on the 3 big players, as opposed to singling every little item out. The stock heads, with small cam, and stock heads, still made 560 ft lbs, and IIRC most were all 500+ ft lbs through the entire pull.
I wonder if it's splitting hairs at that range, but the torque curves definitely moved up as the hp went up. We pulled it a few times to 7200 with the big setup and man.... there aint a sound better!
Re: 430" small block build [Re: DJVCuda] #912923
12/16/12 11:17 PM
12/16/12 11:17 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I just picked up a virgin 71 360 block and I'm tring to decide between a 4.125 and a 4.25 crank.
I'm going the 414 torque curve will remain the same with just another 500 rpm and more hp up in that range.
WIZE
In Car:
Re: 430" small block build [Re: Streetwize] #912924
12/27/12 11:16 AM
12/27/12 11:16 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Please put this most awesome and informative threads in the Tech Archives!
Thanks!
WIZE
In Car:
