Page 9 of 16 1 2 7 8 9 10 11 15 16
Re: 430" small block build [Re: MIKES_DUSTER] #912782
08/13/11 09:43 PM
08/13/11 09:43 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Thanks - It is a PIA trying to get them all at times...lol
Re: 430" small block build [Re: BobR] #912783
09/03/11 11:33 PM
09/03/11 11:33 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Set the end play - It;s right at .005 right where it needs to be - another testament to the BPE crank being dead on balls accurate!
Need to check the clearance of the counterweights?
Need to get in to a tight spot?
Need a flexable feeler gauge?
measure a zip tie ( this one was .060 and the crank spun with it between the counterweight and the webbing.
Rod clearance was right on at .016 - quality rods and quality cranks sure make assembly easy!!!
Re: 430" small block build [Re: DJVCuda] #912784
09/04/11 12:09 AM
09/04/11 12:09 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Looks real purdy!!!!!
Re: 430" small block build [Re: MIKES_DUSTER] #912785
09/04/11 10:08 AM
09/04/11 10:08 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I've used .060" Electrical cable 'Zip Ties' (aka Ty-Raps) to check cam lobe-to- connecting rod clearances and rod to pan rail/bore bottom gaps on stroker motors for years! They're just the right width to get in where a traditional feeler gauge won't go, and in the case of cam lobes I'd just cinch them up tight on the lobes themselves.
Looks fantastic buddy!
WIZE
In Car:
Re: 430" small block build [Re: MIKES_DUSTER] #912786
09/04/11 10:25 AM
09/04/11 10:25 AM
NC
barracuda man Offline
NC
A nice build indeed.Great info.Will this block need hard block?
Re: 430" small block build [Re: barracuda man] #912787
09/05/11 09:06 PM
09/05/11 09:06 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
no it's an X block, and a noticeable increase in strength over a stock block.
& thanks Wize.... it's been a long road.
Re: 430" small block build [Re: DJVCuda] #912788
09/06/11 07:56 PM
09/06/11 07:56 PM
Not sure if you have said how much HP its gonna make and I really didnt want to read thru 9 pages of posts so,How much HP are you hoping it makes??
Re: 430" small block build [Re: MIKES_DUSTER] #912789
09/07/11 09:13 AM
09/07/11 09:13 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
What kind of HP you looking to get out of it??
you already asked....lol
as much as I can....
Re: 430" small block build [Re: DJVCuda] #912790
09/07/11 01:14 PM
09/07/11 01:14 PM
Opps....Been a while!!!!
Re: 430" small block build [Re: MIKES_DUSTER] #912791
09/08/11 10:52 AM
09/08/11 10:52 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
I feel the same way - i dont have a ton of time each week to dedicate to the motor, so its taking a bit.
Re: 430" small block build [Re: DJVCuda] #912792
09/08/11 03:30 PM
09/08/11 03:30 PM
sweden
sshemi Offline
sshemi  Offline
sweden
why would you need to meausure crank throws for cl?
Is it because of the caps?
Re: 430" small block build [Re: sshemi] #912793
09/08/11 03:31 PM
09/08/11 03:31 PM
sweden
sshemi Offline
sshemi  Offline
sweden
One thing that realy amazes me is the quality of your pics.
Re: 430" small block build [Re: sshemi] #912794
09/08/11 04:23 PM
09/08/11 04:23 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
The throws, or more specifically the counterweights were real close to the top of the block - the X block has a little more meat in these areas and it is tight. But it all fits
Re: 430" small block build [Re: DJVCuda] #912795
09/08/11 07:32 PM
09/08/11 07:32 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
SNOB!!!!
Re: 430" small block build [Re: POS Dakota] #912796
09/08/11 08:03 PM
09/08/11 08:03 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
lmao!!!
I'm running a few different combo's on top so its not as easy to nail a number down - probably 500 range is a safe bet!
Re: 430" small block build [Re: DJVCuda] #912797
11/27/11 11:18 PM
11/27/11 11:18 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Just a quick update - Been working a ton, but have managed to get over to work on things a few times and have not updated.
Just about ready to balance after checking and re-checking everything - the shop was impressed with the BPE setup to say the least. They started recommending them to guys inquiring about SBM setups. The fit and finish was better then anything they have touched before in this price range.
Slid both cams in and checked with both heads, the PTV, Radial clearance, and pushrod length was all checked and we are all set.
Radial clearances was checked with clay, Rod's pistons have a ton even with the 2.055 intakes on the ported set of heads, considering the rock of the piston as well.
Pushrods are all at 7.600 - they are all 7.595" long at the last point we checked them so I will be ordering them soon.
Re: 430" small block build [Re: DJVCuda] #912798
12/09/11 10:58 PM
12/09/11 10:58 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
I went with the Manton's 11/32" pushrods. They are an 11/32 x .120 wall thickness.
They are about 50% stronger then a 5/16 ( TOP) - and the 3/8 (BOTTOM) is 50% stronger then the 11/32 ( MIDDLE)
Re: 430" small block build [Re: DJVCuda] #912799
12/10/11 02:15 AM
12/10/11 02:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow Dave that is one fine looking eng you are putting together and you are doing top notch work. I have Manton pushrods also in my 493 and they gave me great service. In fact my adjustable pushrod looks like yours but mine is for the RB block. I missed some of this also but I assume you are putting this in the Cuda ? How fast are you looking to go with this beast under the hood ? Ron
Re: 430" small block build [Re: 383man] #912800
12/10/11 01:48 PM
12/10/11 01:48 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I also ran the Manton 11/32's, Very happy with Terry's expertise and customer service!
WIZE
In Car:
Re: 430" small block build [Re: Streetwize] #912801
12/11/11 10:37 PM
12/11/11 10:37 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Hey Ron - Thanks for checking out the thread - the motor is for a Cuda, just not my 66. I have a few other cuda's sitting around that will have to gone over and get this sucker in there eventually.
