Re: Alternator..how many amps can I run [Re: moparrulzzz] #912092
01/25/11 06:39 PM
01/25/11 06:39 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
As you increase the alternators amperage, the wiring system and respective connections need upgrading. The primary weakness is the 12 guage wire, tab terminals (bulkhead) and the amp guage. If you are planning to raise the system's current pull by adding fans, fuel pump, amplifiers, lights..
I would suggest that the entire wire harness and charging system be upgraded as well..
Just my $0.02..
Re: Alternator..how many amps can I run [Re: Sinitro] #912093
01/26/11 04:24 AM
01/26/11 04:24 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Just my $0.02..
Good advice! The weakest link theory is so true when it comes to dealing with this stuff.
Also, I left the stock charging system in place on my '68, including the points type regulator, and just added a dual field alternator with a solid state regulator, the larger wire directly to the starter relay terminal. It only had the stock electrical loads to support in the car though.
