Re: excessive oling to top end
[Re: hvyweight]
#911700
03/06/11 05:52 PM
03/06/11 05:52 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
My junk has shaft oiling and I sent oil up the exhaust p/rods only with no restriction.The engine was just freshened by ARC and a .030 was installed in the p/r's.From what I gather a .025 to .030 should work for you,but I would rather see Jeff or Dean make that statement.
[Re: hvyweight]
#911701
03/06/11 07:05 PM
03/06/11 07:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
We'll dyno the motor and it didn't go well. Lots of little things. Decided to take the bottom end apart and discovered #5 rod bearing went for s#$%. Started looking at things and I am convinced that I have to much oil to the top. I noticed that the oiling hole in the lifter was in the same path of travel as the bushing in the lifter bore. I have .002 clearance between the lifter and the lifter bore. I was thinking that the clearance would act like a restrictor. I am now thinking that maybe I should put a restrictor in my Manton pushrods or take the lifter bushings out and turn them 90 degrees. What do you guys think?
I dont see how you could turn the bushing 90* and still be in the oil galley... with a .020 I cant believe you have too much oil unless the oil hole in the lifter is lined up while its on seat(that would have oil traveling through the lifter more time... just thinking out loud... I have a .040 restriction in my PRs for my TD rockers on a SB
[Re: AndyF]
#911704
03/07/11 12:46 AM
03/07/11 12:46 AM
Posts: 6,295 U.S.
moparniac
U.S.
andy what do you mean by putting restrictors in the pushrods...... the pushrods of his are already made right!
Mopar Performance
[Re: AndyF]
#911705
03/09/11 06:19 PM
03/09/11 06:19 PM
Posts: 190 Winterpeg, Canada
hvyweight
Winterpeg, Canada
That sounds like a typical Mopar big-block oiling problem. The Isky lifters won't work unless the bushings are clocked correctly. You can either redo the bushings, or change the lifters to the type that IMM has. Putting restrictors in the pushrods can also work, but remember that small holes inside the engine can be easily plugged with debris.
Could you explain clocking the bushings?
