Re: Lunati voodoo cam (60301 and 60302) and 440-4
[Re: BSB67]
#909443
01/22/11 08:18 PM
01/22/11 08:18 PM
Posts: 1,200 UK
602heavy
UK
60301 would be my choice for a nice street car.........don't concern youreself with .050" #s , look & seat duration as this is what determines street manners.
Exactly, and the 302 has shorter seat timing than the factory hp cam. It only have 41 degrees overlap verses the factory 46.
..................& 35* O/L for the 301.
[Re: Chilort]
#909447
01/22/11 09:01 PM
01/22/11 09:01 PM
Posts: 1,200 UK
602heavy
UK
I agree , if the OP wants a good lope @ idle then go maybe 303/304 , i take it the OP wants to carry out minimum mods to get this cam installed , he also has around 8.5 comp ratio , these voodoo grinds are far better than the original cams ever were , intensity #s between .004/.050" on the opening side are around 18/19* , this is the reason smaller is sometinmes better , these voodoos have much more area under the curve than the OE cams had , these cams are what you might call 'sleeper grinds'.
[Re: mini340hemi]
#909449
01/24/11 02:26 AM
01/24/11 02:26 AM
Posts: 528 D/FW
gts95
D/FW
Would the 60302 be friendly in a LOW compression '78 model 440? I'm wanting to slap something into a low-mileage '78 RV mill (now in a '70 Bee)to cruise around with while I build a more serious mill. The engine is bone stock right now...I'm just doing cam, intake, carb, headers, and a good tuning (MP electronic ignition, etc.)
Basically, I need to make sure the voodoos will work with the low compression the later models B/RBs have.
1970 Super Bee, WM21, 383, auto, FY1, a/c, project!
1971 Chrysler 300 2dr, U-code, console car
1980 Chrysler LeBaron LS Limited coupe
2008 Chrysler Aspen, HEMI
2011 Ram 3500 MegaCab, 6.7
[Re: gts95]
#909450
01/24/11 01:13 PM
01/24/11 01:13 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Give Hughes Engines a call. Consider their Whiplash cam.
[Re: gts95]
#909451
01/27/11 10:45 PM
01/27/11 10:45 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
78' 440's have LOW compression. Pistons do sit back a bit in the bore! Need a cam to pump up the low-midrange power. Bees' are usually around 3700- 3900 lbs, depending on options. Low and midrange power works for this scenario. Do the homework on cams for your ride and be REALISTIC about your engine rpm. With bone stock heads, 4500 rpm, maybe 4800 rpm as a ABSOLUTE and power takes a NOSE DIVE, with the parts you have on it now!! And yes, the 302 would be friendly. Better mileage or equal to the Magnum cam, but with a bit more snap from idle with these heads. FYI, always buy a complete cam kit.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
