How well do caltracks drive on street. Special shocks?
#907995
01/18/11 11:32 AM
01/18/11 11:32 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
Hello Do people run their street /strip cars on the street with Cal tracks? If so how do you set it up loose or the same as track? What type of shocks do you run in the Front and Rear? Are there any problems with running the car on the street like this or will it be OK ? The car is a 69 Charger with 493 rb and hemi 4speed with 4:10 Locker I have KYB shocks now and Hemi springs. want to upgrade for the track this season but car does see some weekend to show driving. I might want to buy the mono leafs also. The car only has a 10.5 wide drag radial on it. Looking for people who have real world experience to chime in on this before I plunk down about 900 bills on this . Thank You every body for your help! Moparts has the best people in USA !
1969 Dodge Charger
1969 Dodge Superbee
Re: How well do caltracks drive on street. Special shocks?
[Re: cjs69mope]
#907998
01/18/11 11:48 AM
01/18/11 11:48 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I drive mine on the street the same way I race it. Rides OK to me. A little stiff, but no worse than SS springs.
[Re: cjs69mope]
#908001
01/18/11 12:01 PM
01/18/11 12:01 PM
an8sec70cuda
Rears are Rancho RS9000...the ones Calvert recommends for their setup. Fronts are Lakewood 90/10 that I have somewhat modified.
[Re: Crizila]
#908003
01/18/11 03:49 PM
01/18/11 03:49 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I back the Caltracs right off for the street. If I leave them preloaded it stops the suspension working as it should, if I just back them off a little they bang against the springs all the time. I have QA1 single adjustable shocks all round and Calvert mono leafs. I should point out that I drive the car a lot on the street.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: Mick70RR]
#908004
01/18/11 03:57 PM
01/18/11 03:57 PM
Triple Threat
Renton Washington
I drive around with preload in the bars, as stated it basically stops the rear suspension from being able to work as it should, but if you can stand the ride of a one ton truck you will be fine with the caltracs.
I also use the mono leafs, Rancho 9000's and the Calvert 90/10's up front.
[Re: Triple Threat]
#908005
01/18/11 04:21 PM
01/18/11 04:21 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Same here. Rancho 9000s on the rear and CE 3 ways up front.
[Re: Voluster]
#908007
01/18/11 09:49 PM
01/18/11 09:49 PM
Posts: 12,228 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I run mine a quarter turn loose. That's the way the car likes it at the track and it rides good like that. Any tighter and the ride gets rough.
Calvert used to give you a pair of their wrenches if you asked for them when you ordered their stuff. Don't expect much wrench, but if you need preload at the track and don't like the ride, they make it handy to make the change in settings.
I use a piece of masking tape near the nut that I number each flat on. That way, after I get the set-up that I like I can make changes and not get confused if I need to go back.
Be sure and get the 9 way shocks. You may not need all the adjustments, but it's better to have them and not need them than to need them and not have them. My Cuda needs the stiffest setting at the track. But I run them softest on the street. The shock settings are the only change I make going from street to strip. And the car will consistently 60' in the low 1.5s.
You can get left over 9 way Ranchos from a guy on Ebag for around $75 each.
Master, again and still
[Re: cjs69mope]
#908010
01/18/11 11:02 PM
01/18/11 11:02 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
My brother drives his car all over the place and he drives it with the preload on the springs and its fine. We just switched the shocks out in favor if double adjustable AFCOs in the rear. The front are the QA1 Stocker "R". Hopefully the shocks help us out. Best 60 foot so far has been a 1.401.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: an8sec70cuda]
#908012
01/19/11 12:46 AM
01/19/11 12:46 AM
BradH
x2... It's not worth my time to change it since most of my driving is to and from the track anyway.
[Re: Triple Threat]
#908014
01/19/11 01:18 AM
01/19/11 01:18 AM
Posts: 4,247 Newfoundland
codfish
Newfoundland
X2
codfish
