Re: SOLID ROLLER FOR THE STREET
[Re: dodgeboy11]
#907454
01/19/11 12:36 AM
01/19/11 12:36 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The problem that most don't think about with a solid roller street combo is that street engines idle a lot more than race engines. Without the splash lubrication on the rollers, they can and will fail. And it's much more catastrophic than a flat tappet cam that goes flat. Direct oiling to the rollers is the way to go even on a mild solid roller setup. You NEED enough spring pressure to keep the roller on the lobe though. If it bounces it WILL destroy the lifter.
Thats one of the reasons my 493 going in my 63 will have a solid flat tappet cam. I drive my 63 alot on the street and I dont want to worry about any roller lifter problems. Ron
[Re: 383man]
#907455
01/19/11 09:39 AM
01/19/11 09:39 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
How do all those millions of modern car-engines survive with their roller cam setups? Do those engines all have roller-oiling mods or is it all just a bit of scare-tactics and hearsay? Just curious.
[Re: 383man]
#907456
01/19/11 09:47 AM
01/19/11 09:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The roller lifters I am using have a oil supply hole for the roller... no worry here about lack of oil
[Re: BigBlockMopar]
#907457
01/19/11 10:14 AM
01/19/11 10:14 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Apples to bacon cheeseburgers comparison. A combination of hydraulic roller lifters and mods to the oiling ( oiling the roller for one ) , coupled with WAY tamer grinds let them work like an OEM likes them to. Roller lifters have been around for a long time , but cost and lack of technology to make them last is what kept car manufacturers out of the game for as long as it did.
[Re: Cab_Burge]
#907459
01/19/11 02:17 PM
01/19/11 02:17 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Both my hemi and wedge have solid rollers and have seen a lot of street miles. Do NOT use cheap lifters and you'll be fine. I use Isky Red Zones.
Obviously if it's a real aggressive lobe profile that needs a lot of spring pressure, things will have to be looked at more closely.
[Re: an8sec70cuda]
#907460
01/19/11 02:35 PM
01/19/11 02:35 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
define "aggressive" I'm using a Comp cams 254 int./260 exh (.292/297) 0.582 int./0.588 exh. on a 110* They recommended springs with a seat load of 148 @ 1.900 open load of 456 @ 1.250 coil bind 1.085 and 474lbs.
[Re: Mr.Yuck]
#907461
01/19/11 02:48 PM
01/19/11 02:48 PM
an8sec70cuda
That isn't aggressive. Mine isn't aggressive either...220# on the seat, 600# open.
[Re: an8sec70cuda]
#907462
01/19/11 03:05 PM
01/19/11 03:05 PM
tubtar
St. Paul , Mn.
My personal definition of aggressive starts around .700 lift and 270ish at .050 , but lobe profile has more to do with it than actual lift and duration numbers. under .600 and 250 @.050 would be mild in the roller world......solid roller that is.
[Re: Streetwize]
#907464
01/19/11 06:38 PM
01/19/11 06:38 PM
Mr.Yuck
Brookeville, Md
"Bottom line is if you run your car mainly on week-ends and you pretty much only take it out for occassional cruises or a Test-n-tune, you're probably all right with a street roller." That'd be me except when I go to the track I run 2 classes as I only get out once a month or so... kids...wife ya know.
[Re: Cab_Burge]
#907466
01/19/11 08:54 PM
01/19/11 08:54 PM
Posts: 4,213 New York
polyspheric
New York
keep the rollors in contact with the cam lobes ALL of THE TIME
3 ways to do that: 1. hydraulic 2. set your lash to .001" hot, every day 3. rev kit
Boffin Emeritus
