Vacuum from center carb, 440 six pack.
#907196
01/17/11 11:31 AM
01/17/11 11:31 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. Does anyone know off hand what sort of vacuum readings I should have out of the distributor advance port on the metering block in a 440 six pack application?
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Vacuum from center carb, 440 six pack.
[Re: 62maxwgn]
#907198
01/17/11 11:59 AM
01/17/11 11:59 AM
hemi68charger
Houston, Tx
At idle,nothing.Running depends on cam spec's and engine speed.
It's an OEM cam........... Guess I just need to verify via a vacuum gauge it's drawing vacuum upon increased throttle movement...
[Re: lewtot184]
#907200
01/17/11 12:13 PM
01/17/11 12:13 PM
hemi68charger
Houston, Tx
Thanks guys.. My point is I'm trying to figure if I'm getting the proper vacuum to the good ole' distributor.. Everything about the motor is stock. No aftermarket anything in regards to OEM components.
