Hughes cams #906814
01/16/11 09:07 PM
01/16/11 09:07 PM
Up in the North and Far Away
AutoEngineer Offline OP
Anyone having experiences from Hughes cam HEH1928BL with a 383/440 Magnum and how does it perform?
It looks like having clearly more valve lift and less duration than my old Mopar 383/440 Magnum cam.
Camshaft Technical Details
Intake Valve Lift 1.5 .489"
Exhaust Valve Lift 1.5 .524"
Intake Duration at .050" 219°
Exhaust Duration at .050" 228°
Lobe Separation Angle 111º
Intake Opening at .050" 1.5° BTC
Exhaust Opening at .050" 48° BBC
Intake Closing at .050" 37.5° ABC
Exhaust Closing at .050" 0° ATC
Re: Hughes cams [Re: AutoEngineer] #906815
01/17/11 12:15 AM
01/17/11 12:15 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I would suggest calling or sending them an e-mail.
Dave has helped me out a couple of times and is usually spot-on with advise.
Be honest about what you have and expect and so will he.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
