Page 3 of 4 1 2 3 4
Re: Scat 4" cast crank? Will it break? [Re: mshred] #905160
01/16/11 02:10 PM
01/16/11 02:10 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have went 11teens with mine no problems but If I could turn back time I would have done a forged kit.
Re: Scat 4" cast crank? Will it break? [Re: mshred] #905161
01/16/11 02:49 PM
01/16/11 02:49 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
nevermind
Re: Scat 4" cast crank? Will it break? [Re: cudadoug] #905162
01/16/11 02:56 PM
01/16/11 02:56 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Re: Scat 4" cast crank? Will it break? [Re: mshred] #905163
01/16/11 03:08 PM
01/16/11 03:08 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Bigger may not always be Better....But Bigger IS ALWAYS MORE!!
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
WIZE
In Car:
Re: Scat 4" cast crank? Will it break? [Re: Streetwize] #905164
01/16/11 04:11 PM
01/16/11 04:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Don't get me wrong, if you are thinking about ever wanting to go faster than you should get the forged crank, always build a solid foundation first, than upgrade the top end later. I just wanted to say the cast cranks are not time bombs and are stronger than stock cast witch were better than most manufactures cast cranks.
Re: Scat 4" cast crank? Will it break? [Re: HotRodDave] #905165
01/16/11 04:40 PM
01/16/11 04:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I think much over 550hp. they are time bombs it's been proven several times right here on this board. and I'll keep my factory 360 crank over the chinese pieces any day.
Re: Scat 4" cast crank? Will it break? [Re: Quicktree] #905166
01/16/11 04:46 PM
01/16/11 04:46 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
the forged is olso chinese
Re: Scat 4" cast crank? Will it break? [Re: cbarracuda] #905167
01/16/11 04:48 PM
01/16/11 04:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
true but better than the cast. and some are better than others.
Re: Scat 4" cast crank? Will it break? [Re: cbarracuda] #905168
01/16/11 04:51 PM
01/16/11 04:51 PM
Lehigh Acres, Florida
rickstershemi Offline
Yep and I ran a chinese forged crank in my 900+ hp roadster on a brake 1.12 60' times and 7500 at the stripe w/zero issues
Rickster
Re: Scat 4" cast crank? Will it break? [Re: rickstershemi] #905169
01/16/11 05:04 PM
01/16/11 05:04 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Re: Scat 4" cast crank? Will it break? [Re: Quicktree] #905170
01/16/11 06:14 PM
01/16/11 06:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Not too bad for a crank rated to 500 than huh?
Re: Scat 4" cast crank? Will it break? [Re: cbarracuda] #905171
01/16/11 06:40 PM
01/16/11 06:40 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
All of them ????
Callies is domestic and from everything I read , will be far closer to right as shipped.
B.R.C. ?
Bryant ?
I've only covered the first three letters of the alphabet and you have three nice choices.
It does pay to shop around and do some homework.........especially when buying big ticket items.
Re: Scat 4" cast crank? Will it break? [Re: tubtar] #905172
01/16/11 08:30 PM
01/16/11 08:30 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
All of them ????
B.R.C. ?
Bryant ?
I have no problem going up to the scat forged...just because its chinese doesnt mean jack to me...they check out good the way they are shipped from the research I am doing, and they are significantly cheaper than a comparable american made offerring...in fact, i thought callies forges overseas as well? dont quote me, i thought i read that somewhere though
Re: Scat 4" cast crank? Will it break? [Re: mshred] #905173
01/16/11 08:39 PM
01/16/11 08:39 PM
Q
Quicktree Offline
Quicktree  Offline
Q
All of them ????
B.R.C. ?
Bryant ?
check with Dan on a K1 not much more than the rest and probably the best of the chinese crap.
Re: Scat 4" cast crank? Will it break? [Re: Quicktree] #905174
01/16/11 08:44 PM
01/16/11 08:44 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
All of them ????
B.R.C. ?
Bryant ?
dan?
Re: Scat 4" cast crank? Will it break? [Re: Quicktree] #905175
01/16/11 08:44 PM
01/16/11 08:44 PM
All of them ????
B.R.C. ?
Bryant ?
Callies chinese "Compstar" line kicks ass....but nothing for Mopars
Rickster
Re: Scat 4" cast crank? Will it break? [Re: mshred] #905176
01/16/11 08:46 PM
01/16/11 08:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
All of them ????
B.R.C. ?
Bryant ?
dan?
Dram, performance only on the board
Re: Scat 4" cast crank? Will it break? [Re: Quicktree] #905177
01/16/11 11:19 PM
01/16/11 11:19 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have heard good things about K-1 stuff.
Callies Dragonslayer has a S.B. offering with Chev rod journals.
Decent priced American part.
Check out Competition Products to get an idea of what's out there.
They carry a bunch of different brands and their prices are a baseline.
I wouldn't hesitate to contact a forum member for your best deal.
Re: Scat 4" cast crank? Will it break? [Re: tubtar] #905178
01/16/11 11:50 PM
01/16/11 11:50 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Interesting post I have a 4" cast steel scat crank that's been sittin in the shop for a few years, every time I think about another build I think about using it but end up forkin out for a forged unit, some of the Chevy 400 block guys swear by these cast steel stroker cranks even @ 600+ hp turning 7k, I don't know if they are just lucky or crazy but I have not seen one fail, These engines are used for mud racing so the lack of traction may be a factor
Re: Scat 4" cast crank? Will it break? [Re: emarine01] #905179
01/17/11 12:12 AM
01/17/11 12:12 AM
az
stage3 Offline
stage3  Offline
az
I bought my crank from OHIO CRANKSHAFT and it has a part# P5007258 which I believe is a MOPAR PERFORMANCE part. Is this any good, still in box.
Page 3 of 4 1 2 3 4
