Re: Scat 4" cast crank? Will it break?
[Re: mshred]
#905121
01/15/11 01:44 PM
01/15/11 01:44 PM
Posts: 20,701 in a cattle trailer down by th...
Guitar Jones
I've seen the cast Eagle cranks break with less HP on an automatic car.
[Re: Guitar Jones]
#905122
01/15/11 02:10 PM
01/15/11 02:10 PM
Posts: 45 Iowa
Hey19
Iowa
I am running a 4" Scat cast crank in my all steel 68 barracuda. It runs 10.90's with a 904. I have had it 3 years and it works fine. I race every other weekend. I shift at 6000-6200.
[Re: Quicktree]
#905126
01/15/11 02:25 PM
01/15/11 02:25 PM
Posts: 1,015 Down South
DaKuda
Down South
by the time you get it balanced and finished you will have spent enough for a forged crank..
Dont you have to have the forged crank finished and balanced as well...
[Re: DaKuda]
#905127
01/15/11 02:33 PM
01/15/11 02:33 PM
Quicktree
yea but most take less to balance from what I understand (heavy metal)
[Re: Quicktree]
#905128
01/15/11 03:01 PM
01/15/11 03:01 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Mine took a slug 5/8 x 1.200 to balance that cost a whopping $23 bucks The balance job was $200 ![](/ubbthreads/images/graemlins/wave.gif)
Overall he was very impressed with the crank....me too ![](/ubbthreads/images/graemlins/thumbs.gif)
Rickster
[Re: DaKuda]
#905129
01/15/11 03:02 PM
01/15/11 03:02 PM
Triple Threat
Renton Washington
Yes you balance regardless of the material, but depending on the rest of the rotating assembly Forged cranks generally require less if any mallory slugs to balance. Cast cranks need the added mallory to balance. Each slug is like $50 and a crank can use multiple. Add in some dollars for labor and quickly your budget cast crank costs nearly the same as a forged piece but is still inferior strength wise.
The biggest thing that scares me about your build is the 4 speed. A Cast crank will live at 500 horsepower, but its not going to like you dumping the clutch and so on. A little piece of mind is worth a couple extra bucks. Thats my opinion.
[Re: Triple Threat]
#905130
01/15/11 03:07 PM
01/15/11 03:07 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
well said ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Quicktree]
#905131
01/15/11 03:11 PM
01/15/11 03:11 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
EXACTLY........
Few years back i broke a cast 4 inch stroker crank. I had upgraded my combo from high 10's to 10.30's and it broke after about 50 passes, and ruined the rest of my season. I learned the hard way to do it right the first time.
Like i love saying, spend the extra 500 bucks and get the good piece the first time. In the whole scheme of building a motor, 500 bucks is just a small fraction of the total build, so why scrimp, just wait till you can do it right, then you wont ever have to wonder ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: B3422W5]
#905132
01/15/11 03:16 PM
01/15/11 03:16 PM
Quicktree
EXACTLY........
but some have to learn the hard way.
[Re: Triple Threat]
#905133
01/15/11 03:27 PM
01/15/11 03:27 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
The Scat cranks are great cranks for the money. I like them , use them a lot, BUT, it wouldnt be my choice for a 4 speed car.
Didnt you already buy a kit? I think I saw on BB Dart board you bought one from Coast High Performance ????
RIP Monte Smith
[Re: Triple Threat]
#905134
01/15/11 03:38 PM
01/15/11 03:38 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
A valid opinion , if I do say so myself. The four speed part is my concern too. It " should " take anything you throw at it sounds a lot better than it " might " take anything you throw at it. And a forged crank should take it.
[Re: CHAPPER]
#905136
01/15/11 04:43 PM
01/15/11 04:43 PM
Posts: 3,427 Toronto
mshred
Toronto
hey guys, the kit i bought is from coast high performance and it cost 1300 for probe forged pistons, rings, bearins, scat I beams, and the 9000 cast crank including internal balancing at no extra charge. The only reason im worried is because i saw someone on another forum snap one in two peices with a 4 speed...but, there are alot of guys with cast cranks it seems with good luck...seems like there is a good and bad...Im going to call coast high and see how much it will be to upgrade, but if its outta my range, im gonna cross my fingers and go for it with the cast i was hoping to get real world experience with the cast and 4 speeds, but with the rarity of 4 speed racers, its kinda hard to. thanks, and if anyone else wants to share i appreciate any and all input ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: mshred]
#905137
01/15/11 04:49 PM
01/15/11 04:49 PM
mshred
Toronto
Well Scat and Coast High are closed till Monday, but i just saw this on the scat site http://www.scatcrankshafts.com/scattechpdfs/Break_the_Nose.pdfhopefully because of the internal balancing it may help my cause...I just find it hard to understand why they would sell the cast crank in the 4" arm if it really is a weak point ![](/ubbthreads/images/graemlins/confused.gif)
[Re: mshred]
#905138
01/15/11 04:50 PM
01/15/11 04:50 PM
Quicktree
hey guys,
I would be worried with the 4 speed nad just a note, for $2400 you could have had a forged stroker kit.
[Re: mshred]
#905139
01/15/11 04:52 PM
01/15/11 04:52 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
I'd also put 500 hp at the limit, my 511 horse 427" small block Cobra has a cast crank with a 5 speed, but in a light car it's almost impossible to load the motor up very hard on the street. The heavier the car the more resistence/load you have countering the inherent twisting motion of the crank, if you get into a detonation situation under full-hook/high load and bad things can happen. If you're going to run on street tires I think 500 is safe in an A body, but if you're running Drag Radials or better and really plan on thrashing it around invest in a little extra piece of mind. As said by the time you balance a cast crank you don't wind up saving much over a forging ![](/ubbthreads/images/graemlins/Twocents.gif)
